Old 03-16-2012, 01:07 PM
MF2000's Avatar
MF2000 MF2000 is offline
Vehicle: 2009 Ram Crew Cab
Color: Inferno Red
Rep:13
MF2000 is on a distinguished road
Default Inferno Red Spray Paint
I wasn't sure if this is the right section for this question, but I'll give it a go.
Does anyone know where I can buy Inferno Red spray paint?
I did a search and found one of the small touch-up kits with the brush (P/N P4889836AB...I think) but nothing in a can. I have some larger pieces I want to color match and it doesn't seem all that easy to find. Any help would be much appreciated.
Old 03-16-2012, 01:09 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
I think NAPA is stillable to order cans if you take them your paint code
Old 03-16-2012, 04:13 PM
InDeepWaterBlue's Avatar
Rep:611
Smile
Go here: double u double u double u (dot) automotivetouchup (dot) com
1 12oz is about $20 which is cheap when you consider that a 4oz can from Mopar is $12. The paint matches perfectly I used it to paint the rear badge on my truck and the heat shield on my intake.
Best thing to do is get a couple cans of Krylon base coat and clear coat as well. They dry fairly quickly and can be used on just about any surface with normal cleaning prep work. I used the Clear with the UV protection since I'm in Florida and that sun can be a mess up anything. I think the base and clear were about $2.50 a can.
Old 03-16-2012, 11:23 PM
Mad Cow's Avatar
Mad Cow Mad Cow is offline
Vehicle: 2011 Ram 1500 Sport Lifted 8"
Rep:34
Mad Cow is on a distinguished road
O'rilley auto parts sells it.
2011 Ram Sport Crew Cab 4x4 Hemi fully loaded!! 8" Custom Zone Lift, and Much Much More
Old 03-17-2012, 09:34 AM
MF2000's Avatar
Color: Inferno Red
Rep:13
Thanks guys! You all rock!
Oh, I also found this place too.....but I'm not going to buy from them.
http://www.expresspaint.com/automoti...-C-22p7009.htm
Thanks for the help.....I really appreciate it
Old 03-17-2012, 03:15 PM
Rep:611
No problem, glad to help
