Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Old 04-03-2012, 03:13 PM
ejk78 ejk78 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Gray
ejk78 is on a distinguished road
Question Towing with a Tuner
Hey guys, I have an '04 1500 with a couple mods(CAI, Headers, dual exhaust), I also have a Superchips Tuner that i am curently using the 87 octane program.
My Question is.....if im going to be towing a dual axle trailer with some atvs on it, do i need to change from the 87 program to the towing program from the Tuner? Also sense im using the Tuner program can i NOT use the tow/haul button on the truck? Not sure how sensative these things can be...Thanks
Don't go around....Com on its a RAM, just go OVER!!!!!
Old 04-03-2012, 04:01 PM
Rep:1385
The tow/haul button on the truck is completely independent from the tuner. Use tow/haul as normal, so put it in tow/haul mode when towing.
You do not want to tow on the performance tunes for the most part. You can either switch to the tow tune and use the premium fuel (91 octane) or you can usually also run the 87 performance tune but use 91 octane fuel. The second is the way I like to do it, seems to pull the same but gets slightly better mpg.
Old 04-04-2012, 06:11 PM
Color: Gray
So if i use the tow/haul button as normal, do i have to go back to the stock programming on the truck or can i leave it at the 87 octane program?
Old 04-04-2012, 06:31 PM
Rep:1385
No just use the 87 performance tune with 91 octane, and use the tow/haul button as well. You don't need to be in stock tune to use tow/haul.
Old 05-03-2012, 11:01 AM
Dwyer86 Dwyer86 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: SLT plus
Color: White Gold
Dwyer86 is on a distinguished road
i just ordered the cortex tuner from superchips and was wondering if the gains are noticeable in performance mode and how good the mpgs are in the fuel economy setting
superchips tuner, tow/haul button, towing, towing program
