Old 03-16-2012, 11:39 PM
07HemiRam's Avatar
07HemiRam 07HemiRam is offline
Vehicle: 2007 Dodge Ram
Trim Level: Quad Cab
Rep:17
07HemiRam is on a distinguished road
Default What do these codes mean?
My check engine light came on today and when I hooked up my superchips tuner to read the codes I got a B2215 (FCM Internal) and a P0441 (EVAP purge system performance). What do these mean? Should I be worried? I cleared the codes and so far hasn't came up again. Any help would be awesome!
6000K Bi-Xenon Headlights, 8000K Xenon Fog lights, Superchips Flashpaq, Magnaflow cat-back exhaust, Flowmaster y-pipe, Composite BFI with Amsoil dry filter, Flex-a-lite electric fan, 180* JET thermostat, 85mm Fastman throttle body.
Old 03-17-2012, 09:06 AM
Evil Ram's Avatar
Evil Ram Evil Ram is offline
Vehicle: 2010 DODGE LARAMIE
Trim Level: laramie
Evil Ram is on a distinguished road
Looks like B2215 is a service reflash for TIPM
Code P0441 could mean one or more of the following has happened:
Bad vacuum switch
Broken or damaged EVAP line or canister
Open in PCM purge command circuit
Open or short in Voltage feed circuit to Purge Solenoid
Faulty purge solenoid
Restriction in EVAP solenoid, line or canister
Corrosion or resistance in purge connector
Bad PCM
Hope this Helps you
Old 03-17-2012, 12:31 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
if the fcm (fusebox) was going bad your dash would be acting funny..like this..
Old 03-18-2012, 04:06 PM
bighemi04's Avatar
Rep:623
i get the EVAP code once in a while. tightening the gas cap and unhooking the battery usually takes care of it. or to run a system check you can; while you are turning your key to the on position hold your odometer trip reset and it will run a self diagnostic
Old 03-19-2012, 04:59 PM
07HemiRam's Avatar
Rep:17
Thanks for your help guys! Checked again today and didn't have the P0441 anymore but the B2215 is showing up again...any suggestions??? Also getting these codes:
B1630- Right Low beam control circuit high
B1638- Right Hi-beam control circuit high
B162F- Right low-beam control circuit low
My lights are working fine I just want to get these codes or issues fixed because knowing I have a code on my truck is driving me nuts!
