Old 03-18-2012, 07:53 PM
BigBlue0408's Avatar
BigBlue0408 BigBlue0408 is offline
Vehicle: 2011 Dodge Ram 1500
Color: BLUE
Rep:41
BigBlue0408 is on a distinguished road
Default hey everyone, new on here got a question on suspension...
So i bought a 2011 dodge ram 1500, put a 6 inch pro comp lift on it. it still sits with a rake in front. i brought it down to the shop near my house to have a leveling kit installed but they said they couldnt put any more blocks on top of the front strut. Any ideas of how to level it out without doing an actual leveling kit. any advice helps.... thanks.
Old 03-19-2012, 10:09 AM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
hi
welcome to the forumz
i dont know much about suspension but i,m sure someone will jump in soon
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 02-15-2014, 11:01 AM
colbyscameron's Avatar
colbyscameron colbyscameron is offline
Vehicle: 2011 Ram 1500
Trim Level: SLT 4x4
colbyscameron is on a distinguished road
this problem is extremely common in the 4th gen rams. the issue is this: 4th generation rams have soft rear suspension because they are only 1/2 ton pickups. because of this, they designed the rear to sit a little higher so that when weight is added to the back of the truck, it will sit level as opposed to sagging in the rear. knowing this, procomp designed their lifts to keep the tail end a little higher since it uses the stock rear springs in the lift kit. when you couple those two engineering pieces together, it leaves you with a truck that has a very noticeable front end rake. the easiest way around this is to add some bilstein 5100 adjustable shocks to the front to raise up the front end. the only issue i have with doing so is that it will affect your front end geometry and put your half shafts at a steeper angle which could hurt the performance and longevity of your front end because they are not engineered to run at a high angle like that.
Old 02-18-2014, 05:29 PM
Lincoln5.7's Avatar
Lincoln5.7 Lincoln5.7 is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: SLT Big Horn
Rep:26
Lincoln5.7 is on a distinguished road
i would also look into buying some 5100 adjustable shocks.
Bullydog GT Programmer Tuner, Flowmaster 40 series, 2 Polk MM1040's, 85mm Throttle body, Volant Powercore CAI, McGaughy 2in drop shackles, 22x10 srt10 rims, CCFL Halos, Belltech Street Performance Shocks.
Soon to come: 4.56's and Pacesetter LT with Y-pipe, Cat delete.
Old 02-18-2014, 05:55 PM
jsettle's Avatar
jsettle jsettle is offline
Trim Level: Sport 4x4
Rep:212
jsettle has a spectacular aura aboutjsettle has a spectacular aura aboutjsettle has a spectacular aura about
I have a 2013 4x4 with a 6" ProComp lift as well, I went with the ProRunner shocks all the way around and it sits almost dead level. No noticeable rake at all.
http://www.ramforumz.com/showthread.php?t=160442
6" ProComp lift with ProRunner shocks, limo tint, 35x12.5x20 Hankook DynaPro M/T, 20x10 Fuel Hostage wheels with -24mm offest, 50" LED light bar with roof mount.
Build Thread: http://www.ramforumz.com/showthread.php?t=160442
