Old 03-18-2012, 08:02 PM
Sooner2k1 Sooner2k1 is offline
Vehicle: 2011 Dodge Ram Crew Cab Sport
Sooner2k1 is on a distinguished road
Default Sport Edition Side View Mirror Question
I caught the right side-view mirror on my garage when I was backing out today. I have a white 2011 Crew Cab Sport. I'm hoping to find out if any of you guys know what parts I need.
The damage done is: Mirror is cracked/shattered
The white shell (sport edition) is now has visible scratches from the wall
As far as I can tell there is no major damage to the exterior of the side-view other than the scratches on the white shell, which i'd like to replace.
Hopefully you guys can send me in the right direction, or at least give me a rough estimate of the $$ damage i've done
Old 03-18-2012, 09:22 PM
Rep:2640
I would almost be willing to bet that any auto glass shop would be able to set you up with a mirror, especially if the you didn't lose any metal or plastic parts
In the past i have broken side mirrors & go right to the glass shop in town, they do automotive, residential, & commercial glass & mirrors
They even have sand blasted & acid etched mirrors, beautifully designed
But if you want something more stock
http://www.automirrorglassonly.com/c...1500_2500_3500
Old 03-18-2012, 09:41 PM
I didn't lose any metal or parts, but I did notice that the plastic sport edition cover is a little more lose from being jarred, but I may be able to fix that by figuring out how it is installed, and taking it off and putting it back on.
So if the entire unit (arm, automatic adjustment mechanism, etc...) are in working order, I should be able to just take it to an auto glass place and have it fixed?
Old 03-18-2012, 09:42 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i had to replace mirror assembly on my 04 3500 sport model, back then, about 300.00 if memory serves.
Old 03-18-2012, 09:56 PM
Sorry I have an additional question after searching the forums. Is the white mirror finish that came stock on my Sport Edition simply a snap on mirror cover?
Could I buy a stock black plastic non-sport edition side-view mirror and then move the Sport Edition cover onto it?
Old 03-19-2012, 12:30 AM
Rough 01 Rough 01 is offline
Vehicle: 2011 Ram 1500 Sport
Trim Level: Sport Quad Cab
Rep:67
Rough 01 will become famous soon enough
To answer your question above: It is not a snap on part. Since mine was crashed I was able to see it is a integral part of what holds everything together.
I recently went through this. I have a black sport and I crushed my passenger side mirror. I had to replace it with the expensive factory mirror for the following reasons. My Sport mirror had the following:
1.) Paint matched body
2.) auto dimming
3.) Power adjustments
4.) Power heating
These 4 things were not found in any non-oem mirror I could find. It came to $325 (with shipping) to get a replacement mirror. I looked into replacing both mirrors with lower cost alternatives but those were roughly $130-160 each (total of $260-320) and so the total cost was too close. I liked the look of factory mirrors and ended up saving for a while and then bought the factory replacement. Here is the link to where I found my best deal: http://www.partswebsite.com/dcjpartsdept/
The part number for a black passenger side mirror is: 1QL201XRAD
Hope that helps
Old 03-19-2012, 01:12 AM
Rep:2640
the actual glass that goes into the mirror, comes in 2 types, heated or not
It is only stuck on with double sided tape to the inner workings of the mirror, even the original mirror glass is that way
The glass just sticks to the parts that adjust & move
The site that i posted above is just the glass & tape, both heating type & not heated
Old 03-19-2012, 06:22 AM
Trim Level: sport
Color: green
Rep:657
what about the auto dimming?
Old 03-19-2012, 10:44 AM
2.) auto dimming
4.) Power heating
Hope that helps
Is this what you ended up ordering? Did you install it yourself?
Mirror assy, W/power, w/body color, Bright white Right List Price : $442.00
Your Price : $310.05
Old 03-19-2012, 07:09 PM
Rep:67
That's the one and the price is the same as I paid (before shipping). I made sure to put in my comments section of the order form the make, model, color and year of my truck. I asked them to make sure I got the correct part and I did (they didn't have to change anything).
I did install it myself and it was very straightforward. The only thing I didn't realize was that I would have to take the entire inner door cover off. This is required in order to disconnect/connect the mirror wiring. The only tools I used was a flat head screw driver (to pry the plastic rivets loose on the door panel) and a socket for the 3 nuts on the mirror itself.
Hope that helps
