Old 03-18-2012, 09:57 PM
bigred0603's Avatar
bigred0603 bigred0603 is offline
Vehicle: 2005 Dodge Ram 1500
Color: BLUE
Rep:38
bigred0603 is on a distinguished road
Default Installed pads, Now calipers rub rims.
I changed out the rear brake pads and now the caliper is rubbing the inside of the rim. They are aftermarket seventeens but had no issues until i changed the pads. Any ideas on what to do to fix this or what could be the issue. Thanks Im pretty ticked about it lol
Old 03-18-2012, 10:58 PM
bigred0603's Avatar
Color: BLUE
Rep:38
Also can you put the wrong Pad on the wrong side
Old 03-19-2012, 02:20 PM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
its been a while and i mean a long while since ive done a brake job. dont quote me on this but i dont believe the caliper moves with new pads. it should be in the same place as with the old. the pistons inside the caliper are what move back and forth pushing the pad against the disc. not sure why its rubbing the rim now. seems rather odd since it didnt do it before. hopefully someone more mechanically inclined can chime in and help more than i did. at least this will bump ya back to the top . good luck
Old 03-19-2012, 04:12 PM
bigred0603's Avatar
Color: BLUE
Rep:38
Thanks do you know if u can put the pads on the wrong side or the clip on the wrong side with the pads
Old 03-19-2012, 05:09 PM
lightfighter lightfighter is offline
Vehicle: 2012
Trim Level: Crew Cab Sport
lightfighter is on a distinguished road
just get a 1/4 spacer and that should cure the problem
Old 03-19-2012, 07:04 PM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
daggertats is right the caliper doesn't move only the piston, if it didn't rub before it shouldn't rub now! Pull it apart and go over everything you did, something went back together wrong. If you can't find the problem take it to a shop and let them go over it.
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 03-19-2012, 10:54 PM
bigred0603's Avatar
Color: BLUE
Rep:38
It appears that the new pads are clipping the rim the top and bottom where the clips are are scraping any ideas to fix this and why would it do that when the old ones didn't I have verified and they are the correct pads I'm super pissed
Old 03-20-2012, 05:30 AM
bigred0603's Avatar
Color: BLUE
Rep:38
My dad is wanting to shave the ends I'm not to sure about it another Ideas would be great not sure why the old pads didn't do this and the new ones do
Old 03-20-2012, 09:02 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The CALIPER is rubbing on the wheel? Or the PADS are rubbing the wheel? I don't see how the pads could be...
If the caliper didn't rub before, it shouldn't now either. Some calipers are "floating", or half floating. Usually one side of the caliper is hard mounted (bolted) to a bracket, and the other side of the caliper "floats" on two slide pins. Maybe the new pads are thicker and just pushed the "floating" side of the caliper out further (assuming the "floating" side is the wheel side).
I don't know....this seems bizzare. How about some pics?
Sean
Old 03-20-2012, 09:26 AM
Butter's Avatar
Trim Level: XLT
Rep:398
You should try to take a pic of the part that is rubbing and where it's rubbing on the wheel.
