LED third brakelight - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 03-19-2012, 12:27 AM
pacmann pacmann is offline
Vehicle: 2016 Ram 2500
Trim Level: Power Wagon
pacmann is on a distinguished road
Default LED third brakelight
I bought an ebay led third brakelight for my Ram and installed it, but the red leds stay lit they are real dim but, they come on super bright when the brakes are hit. The cargo lights also stay on for like 15 min. after the doors or unlock button are hit. Do I need a resistor or something?
Old 03-19-2012, 12:45 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2017 Jeep Grand Cherokee
Trim Level: Laredo 75th Anny
Color: Billet Metallic
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
What wire did you use to hook up the aftermarket led light? The cargo light will come on when you unlock the truck. It will shut off when you start it or after a certain amount of time. I'm not sure if that lenght of time is configurable in the EVIC display.
No More RAM
Old 03-21-2012, 08:00 PM
stubie82 stubie82 is offline
Vehicle: 2012 Dodge Ram 2500
Color: Mineral Gray
Rep:36
stubie82 is on a distinguished road
When I installed my RECON LED 3rd brake light, my cargo lights stayed on very dim. I had to install a resistor and it fixed the problem.
I'd do with the resistor.
Old 03-21-2012, 09:32 PM
Stubie82 what size resistor did you use?
Old 04-14-2012, 01:45 AM
ffemtroberts's Avatar
ffemtroberts ffemtroberts is offline
Vehicle: 2015 Ram 1500 Limited
Trim Level: Laramie Longhorn Lim
ffemtroberts is on a distinguished road
My cargo LEDs do the same thing, stay on very dim. I would like to know what size resistor as well, but being an electrically inclined individual, I have lots of resistors just lying around, do I'll do some trial and error and see what I come up with. I'll report back here with my findings for everyone.
Update: 100 ohm 1watt resistor, one side to one wire, other side to the other wire, in other words, wired in parallel to the bulb
"If you've got the biggest stick, why not swing it once in a while?"
Old 04-14-2012, 10:35 AM
Color: Mineral Gray
Rep:36
My resistor is a 6 Ohm/ 50 watt.
Old 05-14-2013, 09:48 PM
misfit1981's Avatar
misfit1981 misfit1981 is offline
Vehicle: 2012 Ram 1500 Quad Cab 4x4
Color: Silver PS2
Rep:45
misfit1981 is on a distinguished road
My buddy just bought the 3rd brake light from Recon, this one came with a resistor already soldered on. But, the cargo lights wont shut off. He's contacting Recon tomorrow, but any suggestions?
its a 2012 Cummings 2500
"To be prepared for war is one of the most effective means of preserving peace." -George Washington
Old 06-27-2013, 03:32 PM
whiteknight312 whiteknight312 is offline
Vehicle: 2012 dodge Ram Bighorn
Trim Level: big horn 4x4
whiteknight312 is on a distinguished road
that's not good that they did not place resistors in the setup. You also need a Diode on the other wire to prevent reverse voltage. the LED will Burn out fast if too much reverse voltage hits them. I do this on my Model railroad lights as people told me to do.
Chris
Old 06-29-2013, 04:01 PM
Color: Mineral Gray
Rep:36
Hmm, sorry I didn't see this sooner. Any luck for your buddy? Recon's pretty good to work with, in my experience. I didn't know they now come with a resistor already on now. I guess the figured Dodge wiring needed them. Makes it easier than getting a new light then waiting for a resistor you didn't know you needed.
I don't know other than talk with them. Good luck
