Old 03-19-2012, 02:15 AM
Gearhead Gearhead is offline
Vehicle: Dodge ram 2002
Color: Blue
Gearhead is on a distinguished road
Default Excessive squeaking
I've started to noticed that coming from my front end area, it's got a over baring squeaking noise every time I go over a bump, uneven roads or even when I'm turning left or right. auto parts guy says it's my (tie rod ends) but the bushings still look good! I've actually greased everything down and it stopped for a while up until I washed the truck and it came back! The noise is embarrassing and I need it to go away!!!!!!! Any pressure I put on the front end, like a incline as far as starting up a hill, or turning at a stopping point, the noise occurs!!
Any ideas would be super helpful!!!
If it's got tits or wheels, it will give you problems.
P-Funk
Old 03-19-2012, 11:39 AM
BWhelan BWhelan is offline
Vehicle: 2007 Ram SLT Regular Cab
Color: Grey
BWhelan is on a distinguished road
Do you have a leveling, body or suspension kit on it? Mine started doing it after I put my Bilstein leveling kit in it. I believe mine is coming from tierod as it's pretty much shot. I will be getting it replaced over the next few weeks, so I'll let you know if it goes away.
Old 03-19-2012, 05:16 PM
Color: Blue
Haven't done any suspension work to it! And the tie rods look fine... Maybe the upper control arms need replacing....
Yeah man that sounds good, keep me posted..
Thanks,
P-Funk
Old 05-08-2012, 12:07 PM
testiclops's Avatar
testiclops testiclops is offline
Vehicle: 2010 Ram 1500
testiclops is on a distinguished road
Bumping this because I have the same issue which has been getting progressively worse for months, and now it is truely horrible. I'm running Bilstein 5100s on the front.
Any solutions found yet?
I've taken it to the dealer multiple times. Most recently they replaced both UCA, tie rods and bushings (all recalls I think and all free of charge). They've also tried cleaning and greasing.
Made no difference.
I have read on other forums that Bilsteins can cause excessive squeaking if the hardware (nuts, washers, etc) aren't put on in the right order or if anything is lose.
I'm going to try tightening the 3 visible nuts on the top of each mount tonight.
"Please contact the Administrator if your date of birth has changed."
Old 05-08-2012, 08:51 PM
mlowney's Avatar
mlowney mlowney is offline
Vehicle: 2006 Ram 1500 quadcab 4x4
Rep:72
mlowney will become famous soon enough
greasing the bushings is only teporary if there not greasible. it could be the sway bar bushings. Good luck
