Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 03-19-2012, 11:02 AM
SawdustJ's Avatar
SawdustJ SawdustJ is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Rep:22
SawdustJ is on a distinguished road
Default Just Did the Front Brakes On My 2010
I finally got the new brakes installed on my 2010. It was a nice day yesterday afternoon, so I dusted off the tools and went at it. I did both pads and rotors. I opted for the Hawk LTS pads and Hawk Quiet Slot rotors. The install went relatively smooth, no busted knuckles, but I did have to modify a 17mm wrench slightly to remove the caliper bolts. In all the installation took about 1.5 hours.
Here are a few pics showing the installation.
Pic 1 - the new pads and rotors
Pic 2 - shows the stock set up with front wheel removed
Pic 3 - caliper is removed. A 13mm wrench/socket was needed to loosen the caliper bolt, but there is also a 17mm backing nut on the caliper itself that needed to be held. My regular 17mm wrench was too thick to fit between the caliper and bracket so I took one of my other lesser 17mm wrenches and ground it a bit thinner so it would fit. With the two wrenches together, the caliper bolts came off quite easily.
Pic 4 - shows the old pads once they came off. The wear between the inside and outside pad was quite even surprisingly, although the inside (piston side) pad a slightly more wear on the leading edge. You can kinda see this in the pic. It's the pad on the bottom (left side)
Pic 5 - shows the old and new pad side by side
Pic 6 and 7 - shows the caliper bracket and bolts. I showed the bolts in my hand to show the relative size of them. I needed a 21mm to loosen those buggers, and they were TIGHT!!! Had to smack the end of the wrench with a hammer to bust them loose.
Pic 8 - shows the old rotor once it was removed. The wear on it was even and as expected.
Pic 9 - shows the new Hawk rotor and caliper bracket installed.
Pic 10 - shows the caliper pistons being compressed back into place. I used a large C-clamp for this. I just had to make sure the clamp was centered as much as possible. On the first try I just had it on one side and as I was squeezing the one piston back in, the other piston was coming out. Moving the calmp over a bit solved that problem
Pic 11 - shows the spring retainer clips on the stock pads. They just had to be pulled off and put on the new pads.
Pic 12 - shows the new pads installed in the caliper bracket. With the clips on the ends of the pads, they were a bit fussy to get into the slots on the bracket. A little tapping here and there solved that. After they were installed I smeared some high temp brake lubricant onto the backs of the pads. A smalled packet of lube came with the pads.
Pic 13 - shows the caliper-installed
Pic 14 - shows the final assembly
Pic 15 - shows all the tools I needed - hammer, 13mm wrench, 13mm socket and ratchet, modified 17mm wrench, 21 mm wrench, C-clamp, and flat head screwdriver (not shown).
After I installed the pads and rotors, I followed Hawks bedding-in procedure.
1. 6-10 moderate stops from 30 - 35 mph
2. 3 hard stops from 40 - 45 mph.
3. Minimum 15 minute cool down period before further use
After each stop, the brakes felt progressively better. When I took the truck out last night to go to hockey, there was a noticable improvement from stock. It wasn't night and day, but it was enough to take notice. At highway speed, when I tapped the brakes, they had a good initial bite, moreso than stock. I haven't really pounded on them (yet) to see how they perform. A friend of mine has a 2011 QC hemi. I'm going to ask him to do a side by side braking test for comparison. I'll post the results of that when I get to it.
There was also a Hawk sticker that came with the pads (seen in the last picture). If someone wants it, send me a PM with your address and I'll mail it to you. Otherwise I'm just going to throw it away
JJ
Mods: Extang Tri-fold Soft Tonneau Cover, Bed Liner, Volant CAI
Old 03-19-2012, 04:35 PM
moparornocar72's Avatar
Rep:630
good job and thanks for the write up, how many miles were on ur truck? reps to ya
14.268 @ 95 MPH Full Trim
Old 03-19-2012, 05:27 PM
Rep:2705
Nice job on the replacements
I also wonder what your mileage is
I have 62,000 miles on my Ram & the dealership has not even mentioned brake pads or rotors yet, they have mentioned a brake fluid change, power steering fluid change, & radiator flush.
I will do the pads & fluid change at the same time, the Rams pads have lasted a year longer than my last truck did, they were at 70% wear at 2 years
Old 03-19-2012, 05:33 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
My 2010 has I think 57,000 miles and my pads are great. I suspect the PO had changed them since they have a lot of meat on them. The truck had 38,000 miles when I bought it about 13 months ago.
Sean
Old 03-19-2012, 06:53 PM
SawdustJ's Avatar
Rep:22
Moparornocar72 - thanks for the rep points. Much appreciated.
My truck has just shy of 70,000 km on it or a little over 43,000 miles.
When I last brought the truck into the dealership for service about 6 weeks ago, they told me the pads had about 10% life left in them. I was skeptical at the time considering the mileage, but knowing what I use the truck for (I am a contractor), and how/where I drive the truck, I figured it was plausible.
But as you can see from the pics, there's still a fair bit of life left in the pads. The wear bar/groove was still well defined. Admittedly, I probably could've gotten another 15,000 - 20,000 km on them without any problem.
Gauging brake wear by mileage alone probably isn't a good benchmark. My driving is probably 60/40 city/highway. I'm sure if it was +80% highway, I could've easily gotten another 50,000km on them or better.
JJ
Old 03-20-2012, 12:11 AM
Ramathorne Ramathorne is offline
Vehicle: 2013 Dodge Ram 1500 Quad Cab
Color: Mineral Gray
Rep:54
Ramathorne will become famous soon enough
I got just about 70,000km on mine and by the feel from my brake pedal, I shall soon be due for news pads...Perhaps rotors as well...I will get a good look at them when I take my winter treads off...
Old 05-05-2012, 12:38 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
I will take the sticker! LOL
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-30k miles-BF Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist, Total Load Control, AVS Visors and Bug Shield, K&N Drop-In, XenonDepot 5000k LED Headlamps in factory projectors.
Old 05-14-2012, 02:31 PM
rustypipes12 rustypipes12 is offline
Vehicle: 2009 Dodge RamTRX4
Trim Level: TRX4
Color: Blue
rustypipes12 is on a distinguished road
I just changed mine at 14,000 miles due to a warped rotor, the pads had a lot of life left on them but I decided to change them and put ceramics on. I also purchased rears but haven't installed them. I went with Powerstop drilled and slotted rotors. Does any body know if the rear rotors are larger?
Old 02-23-2013, 05:06 PM
Jeepdork Jeepdork is offline
Vehicle: 2010 Dodge Ram SLT Crew Cab
Jeepdork is on a distinguished road
Nice and thank you. I am doing mine at a friends house, now I know what tools to bring.
Old 02-23-2013, 10:37 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
im surprised at how little the disks were slotted...
