Old 03-19-2012, 11:39 PM
MidNightExpress MidNightExpress is offline
Vehicle: 2012 Dodge Ram
Trim Level: SLT Outdoorsman
Color: Black & Gray
Rep:29
MidNightExpress is on a distinguished road
Default Calling all RAMBOX Owners with Tonneau Covers
I'm looking for a Tonneau Cover for my new 2012 RAMBOX truck. I would like a cover that seals out rain water and that allows access to the RAMBOX doors with out having to remove the cover. It would be great to see some pictures and get some different ideas. Also if anybody has purchased one that they regret buying it would be good to know that as well.
Old 03-20-2012, 06:55 AM
SHADCHA's Avatar
SHADCHA SHADCHA is offline
Vehicle: 2011 RAM 1500
Trim Level: Laramie with RamBox
Color: Rugged Brown
SHADCHA is on a distinguished road
I have a BakFlip F1 on mine and works wonderful with the RamBox full access without needing to remove tonneau. The tonneau sits flush to the top of the RamBox so it gives it a nice clean look. If you have any questions on it please drop me a line. Install was easy brackets install inside existing rail and can still use the tie downs.
Old 03-20-2012, 07:26 AM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
I have on my 2009 Extang solid fold bought before Backflip had designed for the Rambox. I like the solid fold because I can secure boxes on top when the back is full. I think the difference in design is the Backflip will fold back completely with 4 sections and has drain pipes at the back end, while the Extang has 3sections only 2 section fold and no drain pipes which I have not had a problem with.
e
Old 03-20-2012, 10:56 PM
edd5's Avatar
edd5 edd5 is offline
Vehicle: 2012 Ram 1500 SLT
Color: grey
Rep:17
edd5 is on a distinguished road
Default bakflip cover
I have a bakflip Fibermax cover. Fiberglass top like the F1 and aluminum bottom like the G2. Fits flush, boxes open, bolts to your existing rambox rails. Cheaper than F1 but more expensive than G2. Picture attached.
Old 03-21-2012, 07:13 PM
lightfighter lightfighter is offline
Vehicle: 2012
Trim Level: Crew Cab Sport
lightfighter is on a distinguished road
I have a Back Flip on my Truck........... let me see if I can dig out a pic.....
Nice easy to install.. Installation kit could be a little better but nothing that will piss you off.... I found it for about 550 online
not the best pic you can see its a clean look Ram boxes work perfect and it comes with drain kit to keep the water out also
Old 03-21-2012, 10:11 PM
Color: Black & Gray
Rep:29
I really appreciate the pictures thanks everyone.
Does anybody have a picture of the Trifecta? I have almost made my mind up on the back flip but the fact the Trifecta is alot cheaper has me still thinking about it.
Old 03-24-2012, 06:04 PM
fxitagntoni fxitagntoni is offline
Vehicle: 2012 Dodge Ram 1500
Color: silver
fxitagntoni is on a distinguished road
I'm thinking about the Trifecta too along with the Larado made by Access but I don't have the Ram box.
Old 04-02-2012, 07:52 PM
lightningbolt's Avatar
lightningbolt lightningbolt is offline
Vehicle: 2012 Dodge Ram 1500 Sport
Trim Level: Sport w/ Rambox
lightningbolt is on a distinguished road
Hi, where online did you find it for $550 if you don't mind me asking?
Thanks.
Old 04-03-2012, 08:50 PM
cjiahds cjiahds is offline
Trim Level: Lariat
Rep:12
cjiahds is on a distinguished road
Default Bakflip
Wish me luck with the Bakflip Fibermax.
I ordered from bakflipfactoryoutlet (truckaddons) 3/19/12 to go on my RAMBOX.
Just received today. 12 days to get it
Was really looking forward to installing, but realized they sent the G2.
G2 is not what I ordered.
They did take responsibility for the error, however, I had to pay for another Fibermax AND wait for a return authorization #, then I have to ship back the wrong cover to get the credit back.
Cover ordered 3/19/12.
Now paid for TWICE, go figure.
Still gotta wait 2 weeks.
I hope this Fibermax is worth it.
Old 04-03-2012, 10:32 PM
edd5's Avatar
Color: grey
Rep:17
I got the fibermax from the same supplier without any issues. Its a great cover, you will like it. However, if you have a long (6'4") rambox the directions wont be worth a damn. They provide instructions for the short rambox cover. The covers are different, the long cover is a 4 panel and the short is a 3 panel. Prop bars have different mounts and latch plates go in different spots. If you have not leveled you truck (still have factory forward rake) you won't need to put in the rear drain cups either. Just put the rear latch plates a little further forward and reinstall your rail end caps. You do need the forward drains though. You will get one extra seal strip not covered by the directions, its for the forward box wall top and you only use it if you do not have a bedliner. You will not need it if you have the factory spray in liner either. You will also need to get a tailgate seal to seal up the rear to keep dust from being sucked in. I used a trail seal and it worked well.
