Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 03-20-2012, 04:31 PM
Gearhead Gearhead is offline
Vehicle: Dodge ram 2002
Color: Blue
Gearhead is on a distinguished road
Default High rpm over heat...please help!!!
Radiator is new, fan clutch is new. T-stat and water pump was replaced last year.
I can cruise all day long, or sit at idle....but once I get on it and punch it to 85+ the temp needle will past normal and keep climbing until I slow down!
The radiator was replaced last weekend along with a system flush...
Do you think the T-stat isn't opening up all the way? Some guys on here say go with a 180 stat...Oreily's only have a 195 degree stat.
Where is a good place to get one??....
Hoses have good structure, no swelling, no splits! Open flow!
If it's got tits or wheels, it will give you problems.
P-Funk
Old 03-25-2012, 02:54 PM
THK THK is offline
Vehicle: 02 Dodge Ram
THK is on a distinguished road
You could change the stat but if the same thing is happening, check fan operation or start checking for a head gasket problem developing.
Old 03-27-2012, 01:39 AM
pogster pogster is offline
Vehicle: 2012
Rep:13
pogster is on a distinguished road
Head gasket was my first thought as well. As for the t-stat put in there what's supposed to be in there. Your engine will love you for it.
If you have a bug screen in front of the rad (not the grill) take it off as it can restrict a lot air.
Also, just because a hose looks ok on the outside doesn't mean it's ok on the inside. If they've never been changed now might be the time to take them off and check them.
