Old 03-22-2012, 08:49 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I would run the 87 perf tune on 89 octane, that will be a healty gaibn over stock!
Old 03-22-2012, 01:04 PM
THasse THasse is offline
Vehicle: 2012 Ram 1500
Color: Dark Red
Rep:44
THasse is on a distinguished road
I'm running the 87 tune on it now. I simply asked to see if there is maybe a margin that somebody else has found. I understand that they say not to run any less than 91 in a 91 tune etc, but I also know that a lot of companies will say this type of thing to cover their a$$ if something does happen. I do understand timing and how it affects the engine, what does it hurt to ask if someone else has already tried it and had no issues? I have been debating between running the 93 through to up the avg. octane in the tank so I can run it because no, 91 is NOT available in my area, and 93 is very hard to find. I have one gas station in a 35 mile radius that will sell 93, so thanks Doz for the harsh words, very appreciated. I'm simply going through ideas. I've done a lot of carburetor work, but I'm new to tuners, heaven forbid there be a learning curve. I knew before typing in the question that I'd probably get a long list of no's with the occasional wtf, but now atleast I know for sure, I've been surprised before...
Mods: Deleted Resonator, painted talgate logo, DiabloSport tune, K&N drop in. Plenty more on the way, finances permitting...
Old 03-22-2012, 01:07 PM
Color: Dark Red
Rep:44
And Snrusnack, it's a 4wd, quad cab, short box, with slightly taller tires, not exactly a light truck. Thanks for the help guys.
Old 03-22-2012, 05:53 PM
916Timmy's Avatar
Rep:1443
You can always datalog it to see what the timing is doing, but Dodge PCMs are very quick to pull timing out.
Old 03-22-2012, 07:11 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
Be sad and take it how you want. You said yourself that you understand what octane is and how an engine works so why would it be different with a tuner? Knock is present whether its carb'ed or FI, forced induction or n/a. Its just frustrating to me that people want to spend $300+ dollars on a tuner and get a performance upgrade just to try and be cheap and ask if they can "get away" with running a lower octane.
If you did your research, youd know that most tuners have data logging. If you are unsure if you can run 89 on a 91 tune, data log as thats what its there for. See for yourself if its pulling timing due to detonation. You purchased a product that will answer your question.
Call it harsh if you want, but its reality. Too many people jumping into something they obviously know nothing about without doing their research. You can find GOBS of information between here and other sites about the question you asked. You are spending hundreds, if not thousands of dollars modifying your truck and you are trying to save $.10/gallon on fuel which could potentially harm your engine and negate the money you just spent for performance modification. You are basically willing to hurt your performance and/or engine for $100/year difference in fuel cost. Seriously??? Yeah, harsh reality, deal with it ;/ Maybe you shouldve opted for a Prius.
DS Trinity w/ custom tune, S&B Intake, ARH LT Headers, Magnaflow Cat-back, 87mm PTB, BT Catch Can, 180* T-Stat, v6 E-Fan, 5000k RS HID, XD Misfits w/ 35"x12.5"x18", Rancho QL level, 5% tint w/ 35% full windshield, Hifonics Brutus 1100.1 w/ Sundown SA12 in ported FoxBox
Old 03-22-2012, 07:41 PM
Moose612 Moose612 is offline
Vehicle: 2006 Ram 2500
Rep:26
Moose612 is on a distinguished road
I have a question on this. I understand everything stated already, but I travel often and if I were to need to fill up and the best available was 89 wherever I was driving through What would be my best option? Would running one tank really hurt it, well itd be half a tank cause during trips I fill up every half tank. Or should I take the fifteen minutes to retune?
Living the dream.
Old 03-22-2012, 07:46 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^you'd likely be ok, just would need to listen for detonation/pinging. If your scenario happened to me I'd fill up and listen closely, if it sounded fine I'd continue driving (with an alert ear), if it pinged I'd change the tune. Also, I wouldn't drive it hard (heavy throttle).
Sean
Old 03-22-2012, 11:19 PM
MadSoul87's Avatar
Color: Blue/Silver
Rep:36
I believe there is away to pull back the 91 tune to run with 89 fuel. I am not fully sure on the ratios for that and I know I saw it somewhere on here. Pretty sure it was in the DSP section so dive on in there and see what you can find. That is where I founded all my information on my Trinity before I pulled the trigger on it. Dig in and see what you can come up with and good luck with whichever route you go with. Keep us updated.
My Build Page
Old 03-22-2012, 11:21 PM
doz doz is offline
Rep:76
One tank wont hurt it. Youll be fine. Like has been stated, itll pull the timing and you probably wont even notice it. I personally wouldnt do it daily. Where do you travel that only has 89? Is it higher elevations? If thats the case, then it might not even pull timing as the air isnt as dense and higher octane isnt needed.
hemi, octane, ram, tuner
