Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 03-21-2012, 04:49 PM
countryboy85's Avatar
countryboy85 countryboy85 is offline
Vehicle: 2007 Dodge Ram 1500 4.7L
Trim Level: SLT Big Horn
Rep:16
countryboy85 is on a distinguished road
Default Temp Control Switch Problems
Ok so here's my problem. I can get both hot and cold air, but I have to switch the blend door by hand. I figure it's either the switch that controls the blend door or the wiring that connects the two. Is there any way to test the wires to see if that is the problem? I'm trying to avoid buying a whole new control switch if I can help it. Any suggestions?
Old 03-21-2012, 05:28 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I don't know much about this but isn't the door position controlled by engine vacuum? I know when the vacuum lines get old and crack/leak this is affected. This happened on my old s10 and it wouldn't change vent position (defrost, vent, floor) then I replaced some old vacuum lines and it worked fine.
Sean
Old 03-21-2012, 05:46 PM
Rep:2616
google the youtube videos about dodge heating/ac issues
these 3 are made by heatertreater
Old 03-23-2012, 10:45 AM
Rep:16
I can change the vent possitions fine. Changing the temprature is what I am having trouble with. I've already looked into the heater treater option. The kit they have is to fix the blend door problem. My blend door is operating fine.
I guess I'm just going to have to pay for a new temp control switch and see if that fixes it.
Old 04-01-2012, 06:43 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'd pull the thermal relay out and check it for corrosion or a bad plug. They usually start with the door only wanting to go to dash or some similar type issue, then stops the door from changing all together. Then the fan starts acting up and won't work.
Have you experienced any of these issues?
