Oil change question. Need some advice please. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 03-21-2012, 05:00 PM
persuazion persuazion is offline
Vehicle: 2008 Dodge Ram 1500
persuazion is on a distinguished road
Default Oil change question. Need some advice please.
Hey guys I have a 08 Dodge Ram 1500 Hemi quad cab and recently had the oil changed. The guy talked me into trying a valv synthetic blend for my truck. It only has 53,000 miles on it. Anyways I decided to try it out but today when I looked at the paperwork for the oil change it says they used 5w30 instead of 5w20 as my manual recommends. Should I take it back and get it redone with 5w20 or should I just wait until the next time to change it back. Also should I even be trying the synthetic stuff yet? And will it hurt to flip flop back and forth between the reg and synthetic? Thanks for any help.Not to good at things like this.
Old 03-21-2012, 05:59 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
The Hemi has MDS which depends upon 5w20 to operate correctly. Take it back and make them do it right.
Sure it'll suck, but it'll make you a man
Old 03-21-2012, 06:15 PM
Hmmm. Just got off the phone with the guy and he said they have a paper that prints out and tells them exactly what kind of oil is required for the truck and if its 5w20 then thats what they used. He said sometimes the techs type in the wrong info on the receipt.
Old 03-21-2012, 06:17 PM
Rep:2964
Synthetic oil can be switched when ever you want to do it, although i have not heard of anyone switching back again to the dinosaur oil, i don't believe it would do any harm
Every 1500 model Ram HEMI engine, beginning in 2006 has had MDS & the owners manuals read 5W-20 oil is to be used
the 2500 & up series did Not have MDS & the oil viscosity may be different
as a side note, i buy my Mobile One Synthetic 5W-20 in 5 quart jugs from Walmart & i purchase my preferred oil filter at a auto parts store. My oil is $10 cheaper then what a auto parts store sells the same stuff for
Old 03-21-2012, 10:09 PM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
Yes take it back and have it changed; having the wrong weight oil could void your power train warranty. Unless you have a really good relationship they will likely refuse or claim it is just a mistake in the paperwork. If they do, threaten to take them to small claims court for the cost of having the oil changed elsewhere. It has been done before and is an open and shut case as any certified service center is required to know the OEM requirements.
Absolutely, synth is better; no it won't hurt to go back but why would you. Just have the correct weight of synth put in.
Old 03-22-2012, 10:19 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:801
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i would make them change it. if they don't, tell them your paper wok says they used the wrong oil, and when something goes wrong you have the paper work to prove it in court.
Old 03-22-2012, 04:55 PM
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:134
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
I wouldn't worry about it. Some 5-30 can be as thin as a 5-20 especially if its a synthetic. You wouldn't know the diff., neither will your engine.
Old 03-22-2012, 05:56 PM
5500 5500 is offline
Vehicle: 2012 Ram 1500
Rep:12
5500 is on a distinguished road
Most modern engines require a multiviscosity oil with a cold weight of 5 (the first #) in order for modern sofisticated valve trains to work properly when cold, including Rams. These engines require immediate oil flow, and thicker oils do not flow as easily when cold. However, once the oil is warmer, flow is not an issue as the oil thins out with increased temperature.
No problems switching back and forth from reg to synthetic at your mileage.
There's a lot of information available at Bobistheoilguy (not affiliated, employed by or otherwise related to the site).
Old 03-22-2012, 06:39 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Synthetic is fine at any mileage, don't believe the "myths" that say otherwise. There's also no issues with switching back and forth between synthetic and conventional. Also, no synthetic will not cause leaks.
Sean
Old 03-22-2012, 09:18 PM
raceram9's Avatar
raceram9 raceram9 is offline
Vehicle: 07 Flame Red QC
Trim Level: Sport-R/T
Rep:51
raceram9 will become famous soon enough
Ive done this myself...with no issues.....it will not hurt the engine, or void your warranty,Ive run full syn. in my truck since the first oil change. Just use this as a lesson learned and I am sure you will pay closer attention next oil change.
2007 RAM QC FLAME RED,20s, 3.92 rear Vararam CAI, Cherrybomb vortex mufflers dumped out in front of rear tires, Superchips Cortex, R/T badges on grill and tailgate custom designed stripes and hood vinyl.....and more to come
