Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
Old 03-22-2012, 07:26 AM
2012Longhorn 2012Longhorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Longhorn ~V~
Rep:31
2012Longhorn is on a distinguished road
Default MDS Disable on our 2012s
From what I understand, on the 5 speed trannys, you could just bump the shift once to the left to put it in "5" and that disables the MDS.
On our 2012s, if you bump it once to the left, it goes to "1"...would I then bump it to the right 5 times until it displays "6" to disable MDS?
Old 03-22-2012, 08:51 AM
dkerr24 dkerr24 is offline
Vehicle: 2011 Dodge Ram
Color: Dk Cherry Red
Rep:14
dkerr24 is on a distinguished road
correct.... the shifter will go to the current gear you are in.... so if you were at cruising speed and hit the shifter, you would go into '6'.
Darin
Old 03-22-2012, 11:17 AM
Rep:31
Darin
Makes sense, thanks.
Old 03-22-2012, 11:50 AM
Trim Level: sport
Color: green
Rep:643
some have posted better mpg in town, not hwy, by locking out six on the shifter.
Old 03-22-2012, 01:48 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
I like to stay in 4 or 5 sometimes when in the city. I get better throttle response. I'm sure it has a slight hit on MPG.
Old 03-22-2012, 02:22 PM
jeepgrady's Avatar
jeepgrady jeepgrady is offline
Vehicle: 2012 Dodge Ram 4X4
Trim Level: 1500 Big Horn Quad
Color: Saddle Brown
jeepgrady is on a distinguished road
Doing this does not disable MDS. All it does is pick the top gear you want to drive in just like downshifting. Has nothing to do with MDS.
Old 03-22-2012, 03:11 PM
Tubbs1 Tubbs1 is offline
Vehicle: 2012 RAM Hemi Crew Cab
Trim Level: RT
Color: Deep Cherry Red
Rep:31
Tubbs1 is on a distinguished road
In order to off the MDS all you have to do is put the truck into Tow/Haul and it will give full power until you turn it off.
Old 03-22-2012, 07:38 PM
jeepgrady's Avatar
Color: Saddle Brown
Placing it in tow/haul also does not turn off the MDS. All it does is downshift the tranny into 3rd gear.
Old 03-22-2012, 07:57 PM
Rep:2616
on my '09 with the 545RFE 5 speed
the MDS is enabled only in the highest gear, 5th over drive
If my EVIC reads Fuel Saver, the MDS is engaged
On the 2010 & newer Rams, it will read ECO instead of Fuel Saver
look at the light beside the odometer
http://imageshack.us/f/829/img0620nv.jpg/
Old 03-23-2012, 09:59 AM
Trim Level: RT
Rep:31
On the 2012 RAM's if you put it into Tow/Haul the engine will not go into "eco" mode which is the name they have for it when it shuts off 4 cylinders. Also MDS is not a mode it is a type of ENGINE, MDS (Multiple Displacement) engine, "eco" is the mode you are trying to avoid where is shuts off the cylinders, Correct? So put it into Tow/Haul and give it a try I bet you never go into "eco" mode. On the 2012 I am not sure what you are driving. Either way I hope this helps and you get everything figured out.
