MDS Disable on our 2012s - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
Old 04-25-2012, 12:35 PM
Hemi Joe Hemi Joe is offline
Vehicle: 2012 Regular Cab Hemi Express
Trim Level: Regular Cab Express
Hemi Joe is on a distinguished road
Originally Posted by jeepgrady View Post
Placing it in tow/haul also does not turn off the MDS. All it does is downshift the tranny into 3rd gear.
Wrong again bud...
Old 04-25-2012, 12:40 PM
Originally Posted by jacobson.s View Post
When you turn ON tow/haul my truck WILL go into eco mode still. Only if you have it manually shifted in gears 1-6, then ECO will stay off.
Mine doesn't. The owners manual even states that Tow/Haul mode disables Eco mode.
Old 04-25-2012, 01:18 PM
2012RamBigHorn 2012RamBigHorn is offline
Vehicle: 2012 Ram Big Horn
Trim Level: SLT Big Horn
2012RamBigHorn is on a distinguished road
tow/haul mode is not correct at all I do this everyday and every time I drive the truck folks I am talking from experience
in the 2012's with a steering wheel shifter you put it in D and once your moving use the +- to get to 5th once in 5th hit both the +and- (+-) at the same time once and quickly it will automatically shift into 6th on the screen however all gears still work and everything works as normal all you have done is disabled MDS/ECO as I said I do it daily and I have gained MPG in both hwy and city
here's the link that 1st taught me how to do it
http://www.ramforumz.com/showthread....ht=disable+mds
Old 04-25-2012, 01:32 PM
For everyday driving you are correct, that's exactly what I do when I don't want the MDS to kick in. However, Tow/Haul mode is something completely different. Think of it as "sport" mode, the shift points are more agressive, throttle response is different, and it kills the ECO mode. The owners manual tells you to use Tow/Haul mode when driving back roads/hilly roads to avoid excessive shifting and MDS engagement.
Old 04-25-2012, 02:54 PM
I agree tow/haul does have it's advantages but from what I have learned it limits you more so than the +- solution the tow haul mode actually robs you of a gear when the +- way allows for the full use of all 6 gears on the 2012's
check out this post
www.ramforumz.com/showthread.php?t=94583&page=2
Old 11-05-2012, 10:02 PM
Voisey Voisey is offline
Vehicle: 2012 dodge ram 1500 Sport
Color: Blk
Voisey is on a distinguished road
Default Mds
As said in previous threads !
To turn off MDS just put your gear selector in the -/+ selector mode for 2009 - present models for Hemi 5 or 6 speed.(some people may know this as tiptronic, touchshift, sporttronic etc..) The tow/haul option will do the same but not recommend.( If you have lots of vehicle warranty left, then go for it )
Tow/Haul, is meant exactly for that.
The reason why people want to eliminate MDS is B/C they have after market exhaust and mod's done to there 50 thousand dollar fully loaded trucks. (CAN)
At cruising speeds highway/city, when the MDS kicks in i.e ( ECO, Fuel Saver).
The drone from the exhaust in city driving, makes your performance exhaust sound like its more less stalling. At highway speeds around 110-120 Km/H when MDS kicks in it has a real deep low drone that again sounds like Sh*T ! lol
Old 11-05-2012, 10:48 PM
Grubrunner's Avatar
Rep:3883
Originally Posted by ONOutdoorsman View Post
I like to stay in 4 or 5 sometimes when in the city. I get better throttle response. I'm sure it has a slight hit on MPG.
Doing this does not disable MDS. All it does is pick the top gear you want to drive in just like downshifting. Has nothing to do with MDS.
Originally Posted by Tubbs1 View Post
In order to off the MDS all you have to do is put the truck into Tow/Haul and it will give full power until you turn it off.
jeepgrady,
Both my dealerships' Service Managers and more than a couple of Chrsylser Techs have confirmed the exact opposite of what you claimed.
No idea who's feeding you but you are clearly WRONG!
..... as Hemi Joe called you on.
Grub out!
Old 11-06-2012, 11:27 AM
jeepgrady's Avatar
jeepgrady jeepgrady is offline
Vehicle: 2012 Dodge Ram 4X4
Trim Level: 1500 Big Horn Quad
Color: Saddle Brown
jeepgrady is on a distinguished road
Originally Posted by Grubrunner View Post
jeepgrady,
Guess you finally woke up. Those were posted 8 months ago. On the other hand, you are correct.
Old 11-06-2012, 07:02 PM
BlueRamMan34 BlueRamMan34 is offline
Vehicle: 2012 Dodge Ram Laramie
Color: True Blue Pearl
BlueRamMan34 is on a distinguished road
^^ %100 correct. well said.
Old 11-06-2012, 07:17 PM
Grubrunner's Avatar
Rep:3883
I knew how long ago it was when I posted.
So it took you 8 months to conceed you were wrong?
Grub out!
