Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
Old 12-19-2012, 07:13 PM
viperr817's Avatar
viperr817 viperr817 is offline
Vehicle: 2012 ram
Rep:195
viperr817 has a spectacular aura aboutviperr817 has a spectacular aura about
I'll chime in my experience. I live 2.2 miles from work all city drive truck is parked in heated garage and i start and go. When i leave work i start it 10 min prior. In eco mode i got 12.8-13 for a week. The next week i made sure to disable mds and observed 11.3-11.5. I have done this test numerous times each time resetting the evic. Just what i have observed.
Old 12-29-2012, 06:33 PM
Red-Stripe Red-Stripe is offline
Vehicle: 2012 ram
Rep:117
Red-Stripe will become famous soon enoughRed-Stripe will become famous soon enough
I get better milage leaving all 8 cylinders running normal.
4wd- long bed.
I've got the large gas tank, so If I run it till it's low I get a very accurate average of the mileage. My normal driving is from 40-55 mph, with maybe a small amount of city.
I've now run 4 complete test tanks of gas. 2 letting the "eco-mode" and MDS run as it wants, and 2 full tanks pressing the "-" to set "6" before each trip.
I also alternated eco, normal eco, normal, so that seasonal gas formulas, and weather were not factors.
I started the tests after 3k miles
full tank #1 MDS ---------------16.2 mpg
full tank #2 disabled "eco-mode" 17.5 mpg
full tank #3 MDS ---------------16.8 mpg
full tank #4 disabled "eco-mode" 18.0 mpg
full tank #5 MDS ---------------14.6 mpg one day with snow/slush
full tank #6 disabled "eco-mode" 15.5 mpg two days with snow
I drove the first MDS tank with the display visible, and the 3rd tank with it hidden, so it didn't influence my driving.
Updated tank 6
There seems to be is a real problem with my "eco-mode" and the MDS. I always burn more fuel in 4 cylinder mode.
Old 12-29-2012, 08:44 PM
cclark666's Avatar
cclark666 cclark666 is offline
Vehicle: 2012 RAM 1500
cclark666 is on a distinguished road
Originally Posted by jeepgrady View Post
Doing this does not disable MDS. All it does is pick the top gear you want to drive in just like downshifting. Has nothing to do with MDS.
It most certainly does turn MDS off. Give it a rty
Spintech Exhaust. Bilstein 1500's. aFe Stage 2 Intake. JBA Headers. Diablosport Trinity (with HemiFever tune). Catch Can. 190 tStat. Moe's 85mm Throttle Body.
Old 12-31-2012, 01:06 AM
Platelock Platelock is offline
Vehicle: 2012 Dodge Ram 1500
Color: Dark Grey
Platelock is on a distinguished road
Probably a stupid question but do the 4.7s have MDS? I don't think they do. Just curious.
Also will I get better torque response if I am driving around town and I leave the ERS in 5th or 6th?
Old 08-04-2013, 09:24 PM
superdlb's Avatar
superdlb superdlb is offline
Vehicle: 2015 Ram 1500 CC 5 7 bed 4WD
superdlb is on a distinguished road
It does disable it as long as you are not in drive. So if you mean it does not permanently you are right, but in order for the mds to work the transmission must be in drive. It will not work in any other position as per owners manual. also if you put it into 6 gear you get all the slipping in and out of different gears but if in 5 gear it will give you full power and and stiff shifts.
Old 08-04-2013, 09:28 PM
superdlb's Avatar
Originally Posted by DWWHemiguy View Post
My truck never goes into eco as long as you have it in manual, even if 6 th gear is selected.
It must be in drive before it will work.
Old 01-21-2015, 05:41 PM
Vehicle: 2012 ram
Rep:117
Yeh, I know this is an old thread, but I figured I'd follow up with an MDS positive after all my negative.
Recently had dealer perform TSB 18-050-14. Thanks to the 2013 guys here.
Truck is MUCH better now. It's actually enjoyable to drive now.
Old 01-21-2015, 09:45 PM
Jack65's Avatar
Jack65 Jack65 is offline
Vehicle: 2012 Ram 1500
Jack65 is on a distinguished road
From my experience TOW/HAUL mode does the job but that is just my case. I know for a fact some tunners will do this but which one is right for you? research and find out
