Old 03-23-2012, 02:13 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Default No cats check engine light
Hey guys I have not been around recently but i back. Ok it seems that i getting p0157 which i know is 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2). Also i get bank 1 sensor 2 issue. I tried to put the non foulers in still get the cel light. I cant get a hold of watson performance for a new tune. I stuck I keep clearing the codes I was wondering if you guy can figure anything else out.
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 03-23-2012, 12:31 PM
Milla Gorilla's Avatar
Milla Gorilla Milla Gorilla is offline
Vehicle: 05 Dodge ram 1500 thunder road
Trim Level: Slt
Color: Gray
Milla Gorilla is on a distinguished road
Are you running any cats? I'm sure you already know, but our trucks(like all cars/trucks) need to have the cats to get a correct reading for the O2 Sensors. Hows your gas Millage, Have you seen any sudden Drops, or at idal or start up, does it run lean/rich? But there are a couple of ways to get rid of the light/code. 1. get an aftermarket cat. there kinda expensive but there really nice, non restrictive, and it gives the exhaust an almost scary tune...2. go to a tuner shop and have them flash the system and remap it out to not read the O2 sensor, 3. and this is what i did in my Old truck.... Just take the light out of the dash,.... But in my opinion if you love your truck you should just look into buying an aftermarket cat.....
Old 03-23-2012, 01:19 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
bank 1 is drivers side and sensor 2 is your rear sensor. Maybe replace the o2 sensor, clear the code and see how it goes. Do the same with your passenger side rear o2's since you are also getting bank 2 sensor 2.
Old 03-24-2012, 06:21 PM
Trim Level: st
Color: silver
Rep:68
i tried new o2 sensor i keep getting it help
Old 03-24-2012, 06:27 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
how is your plug fouler setup? did you stuff the 1st one with steel wool? (2 per side)
5.7 e.t.'s: 1/8 - 7.85@93.20, 1/4 - 12.10@113.96 juice - 12.96 NA... 6.4 e.t. 12.59@106 NA
Old 03-24-2012, 06:29 PM
chefred112's Avatar
Rep:656
I run no cats with fouler setup and no codes...
Old 03-24-2012, 06:30 PM
chefred112's Avatar
Rep:656
mike..since you have diablo, have your tuner write a tune to turn them off...
Old 04-01-2012, 11:39 PM
Trim Level: st
Color: silver
Rep:68
sorry guys been off for a bit no one tunes any more lol I dont know who to trust. I have this
http://www.google.com/imgres?q=non+f...:429,r:18,s:18
I drilled the middle out so i should put two of them inside each.
Old 04-01-2012, 11:40 PM
Trim Level: st
Color: silver
Rep:68
no i did not stuff them
Old 04-02-2012, 01:45 AM
chefred112's Avatar
Rep:656
stuff the bottom one with steel wool....
also, are you getting custom tuned yet? use one of the tuners that have experience with hemis and rams..very important.
this is my tuner and he does great for everyone he's tuned for..
David Amalong <davidamalong@yahoo.com>
