Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 03-24-2012, 04:14 PM
formulafan formulafan is offline
Vehicle: 2002 Dodge Ram 1500
Trim Level: ? Basic
Color: Charcoal Grey
formulafan is on a distinguished road
Default My truck is dead.
Hi guys, I hope someone can help me? When i went to start my truck nothing works, no lights,radio,horn,nothing, just a red flashing light in the gauge cluster beside the temp gauge. I tryed boosting it and everything worked but the truck would only run if i kept the rpms up, as soon as i took my foot off the throttle the truck would stall. I tried to start it again & same thing nothing . Any help would be great thanks.
Old 03-24-2012, 05:13 PM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
Have you checked to see if the alternator is bad? start it and have someone unhook the neg battery terminal and if it stays running its good if not then theres part of your problem. but I am not a tech. This would be the first thing I tried.
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 03-24-2012, 10:29 PM
Trim Level: ? Basic
Thanks for the advice, just after i posted my message my fatherinlaw came by he had a volt meter & checked the battery it read 1.6volts. So we boosted it with his truck and my truck fired right up & ran fine. We then unhooked the cables & checked the battery with the meter & it read 14.3 volts. Not sure whats going on, any ideas. Thanks again.
Old 03-25-2012, 07:41 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Change the battery. Crank the truck after and see how the volt meter on your dash reads. Dont overthink this, change the battery and go from there.
Sure it'll suck, but it'll make you a man
Old 03-26-2012, 08:30 PM
Trim Level: ? Basic
Well as of today the truck starts & runs fine & the volt gauge is reading the same as it did before this problem. I think you might be right about the battery being the problem, but i was wondering if the alternator could be an issue also? Is it one of those parts that either works or it doesn't or could it work off and on? Thanks for your help.
Old 03-26-2012, 09:42 PM
HemiLonestar's Avatar
Rep:280
If you read 14.3 volts on the battery while the truck was running, then it isn't your alternator. Normal reading would've been 13 and change, but it's reading 14+ trying to charge your battery that won't charge properly.
"Big Red"
2006 Charger R/T
Old 03-26-2012, 09:53 PM
Rep:69
Yup, HemiLonestar is right about that, good call man. Battery is pooched evidently.
Old 03-26-2012, 09:56 PM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
Chances are it was just the battery.
Old 03-29-2012, 08:36 PM
Trim Level: ? Basic
Thanks for your help guys i will be changing the battery. I'm glad that it wasn't something more serious (expensive). I've only owned the truck for 4yrs but know the history of it & sure its the original battery so its probably due to be changed. Thanks again.
Old 03-30-2012, 11:08 PM
Tommycat Tommycat is offline
Vehicle: 2004 Dodge Ram
Rep:22
Tommycat is on a distinguished road
Honestly with the temps warming up I would check to see if the battery was actually bad, or if the terminal was just loosening up.
Always happened with my truck in the spring
