Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 04-09-2012, 04:41 PM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Also what program will they be using to do the custom tune on the Dyno? That is what i was going to do but a buddy of mine from the performance shop said the program has not come out yet. I believe he called it the HP TUNE
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 04-09-2012, 04:49 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
HP Tuners has been saying they will be releasing tuning for chrysler for years. I am becoming doubtful it will ever happen, however when I emailed them they said they are in fact still planning on releasing it.
I believe BRH will be using diablo/CMR.
Sean
Old 04-09-2012, 04:53 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
Good deal,
I remember looking into that 4.10 rear diff shortly after getting my Truck,
unfortunately the shipping to Canada would negate any savings,
and I've still got a front diff I'd have to match.
I'm looking at $1800 parts (Gears,Locker, bearings etc.) Front and Rear
and about $1500 in labor
Diablo Tuners use Chip Master Revolution software (CMR)
Link: http://www.diablosport.com/index.php...=display&pid=8
Old 04-09-2012, 08:10 PM
hemiexp04 hemiexp04 is offline
Vehicle: 2014 blacktop qq 4wd 8speed
hemiexp04 is on a distinguished road
4.30 would be a no-brainer, but that's not an option for a Chrysler 9.25 diff.
It all comes down to the number of teeth on the pinion in relation to the number of teeth on the ring gear.
as a result I'm afraid I'm faced with settling for 4.10's
or going to 4.56's and needing to buy 4 new DR's that sit about 29"-30" tall.
The key is definitely to stay out of 4th gear before hitting the traps.
I cant do any track testing or detailed calculations until I get back to the track,
I need to know my exact RPM's at the line but our track doesn't open until April 27th.
My effective gear ratio with 3.55's and 27" DR's is about 4.30:1
I believe I'm 4400-4600 rpm in 3rd gear, but not 100% sure.
If I can get to 5800 in 3rd with 4.56's and my current tires, that will be the determining factor.
If I'm wrong and I shift into 4th. I'll be in overdrive at 3000 rpm at the traps, and have to shop for new tires.
I may scrap the entire gear swap and just add a rear LSD, then spray it
Why struggle for mid/low 13's when I can get 12's for less $$$.
With you haveing 4wd i would probably ditch the gear swap and just do the lsd. Its really not worth the money. You could do a cam swap, stall or somthing and still be cheaper. With you crossing the line at that rpm i would try some spray and see what happens maybe a 100 shot and youll be deep in the 12s and if you have problems with rpms at tht point change tires or smthn. just my .2
Old 04-10-2012, 12:01 AM
InDeepWaterBlue's Avatar
Rep:611
Originally Posted by Darkknight3829 View Post
I found a 4.10 rear end setup for 1200$ on the online mopar store. Went by the dealership to confirm what exactly it was that I would be receiving because it seemed cheap. And turns out to be everything you need for a gear swap. 1200$ aint bad. Im running 3.55s as well. I plan on swapping to 4.10s as my last mod on my truck.
I run the exact same tire as you when at the track. MT drag radials. just a different wheel.
Now that i saw those wheels (Your track wheels) on your ram. I may have found the set of wheels ive been searching for to put on mine
Does that include the LSD as well or is that just the gears, I'm a slight newb to this whole rear diff thing, I want to swap out the 3.55's for the 4.10's with a limited slip so I'm not peg legging it anymore.
Old 04-10-2012, 09:08 AM
Rep:561
It's the entire R/T rear axle assembly, all ready to bolt in
Housing, Gears, LSD Carrier, Axle Shafts already assembled.
I think all you do is swap your own brakes over.
http://moparonlineparts.com/repair-parts.php
third selection on this page...
The axle change is a pretty easy for the average shade tree mechanic to swap, just a driveshaft, control arms, track bar, brake lines.
installing and setting up a ring/pinon takes a skilled tech that can charge you more in labor than the price of the gears/carrier/install kit and bearings alone.
If your 3.55 rear axle is still fairly new, you can sell it to recoup some of your cost,
Old 04-10-2012, 09:20 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
swapping out the 3.55's for any other gearing upwards is a no brainer... doesn't make sense to mod everything else when the gearing should be a part of the list...
Old 04-10-2012, 09:24 AM
Color: Gloss Black
Rep:141
Exactly..
It's the entire R/T rear axle assembly, all ready to bolt in. Just have to transfer rotors, brakes i believe. So you wont peg leg it anymore with the 4.10 setup. The 4.10 comes on the R/T. Thats why he is saying its the R/T package. The 3.92 is an option on regular Ram 1500's. I think some 1500's come with a 3.72 (Dont catch me lying i am unsure of this)
Old 04-10-2012, 09:28 AM
Color: Gloss Black
Rep:141
Good deal,
Oh yea haha shipping plus labor would kill you. Didnt take that into consideration. Since the mopar dealership is here I can just pick it up an do the install myself when i get around to getting myself the 4.10's.
Wow i was never introduced to this before. Am i seeing this right. 2500$? Or does the performance shop your going to already have this? That is pretty cool. I didnt know of this program.
Old 04-10-2012, 09:31 AM
Color: Gloss Black
Rep:141
Gearing is the last on the list. Because of $$$ & the time it will take me to do the install myself
Definitely a MUST If i want to reach my goal or rather have a complete build.
