switching from conventional oil to synthetic - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 03-26-2012, 01:11 PM
Grubrunner's Avatar
Rep:3883
I drove my new '12 Ram home with 7-miles and immediately changed the oil/filter to Amsoil synthetic and Wixx filter.
I've been doing this for the last 6 new vehicles purchased [Ram inclusive].
How long has that oil/filter been sitting in your vehicle for?
Food for thought....
Grub out!
Old 03-26-2012, 01:22 PM
shadango shadango is offline
Vehicle: 2012 Dodge Ram 1500 Big Horn
Rep:25
shadango is on a distinguished road
Originally Posted by C Jones View Post
I've switched the last three cars I've owned to Mobil 1 5W-20...and I agree with Rolinfast that you wait for your first oil change after breaking. That allows the engine to break in properly, then flush out the particles that might have been generated during the break in period. If you have an automatic, there'll be some of the old oil left int the torque converter that you can't get out, but it will just be diluted with the old and at the subsequent oil change down the road completely gone.
Are we talking tranny fluid or engine oil?
Old 03-26-2012, 01:23 PM
Rep:25
....dang....I never thought of it that way......
Hmmmmm......now you have me thinkin' I need to do an oil change. (50 miles on mine)
Old 03-26-2012, 05:19 PM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:783
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
I've switched the last three cars I've owned to Mobil 1 5W-20...and I agree with Rolinfast that you wait for your first oil change after breaking. That allows the engine to break in properly, then flush out the particles that might have been generated during the break in period. If you have an automatic, there'll be some of the old oil left int the torque converter that you can't get out, but it will just be diluted with the old and at the subsequent oil change down the road completely gone. I've run Mobil 1 is everything from my previous one ton dually to the Porsches....it's probably one of the best synthetics on the market. Don't cheap out on your filter either....a good filter can save you a lot of wear on the engine.
If you opt to just use the oil provided by the dealership, you might want to ask what brand they use. they usually buy in bulk and the brands vary from dealership to dealership. The dealership I bought the truck from uses Penzoil...too much parafin for me. Since I can't crawl under cars anymore to change my own oil, I just buy it from Walmart (best price I've found for Mobil 1) and they charge me $14 to change it out for me.
read up on the castrol oil law suit, you will find m1 and all the others are no longer the true synthetic they once were. all comes from the same base stock, same as dino.
also, is that a porsche in your avatar, thought they came from the factory with synthetic.
Old 03-26-2012, 05:22 PM
Rep:783
jones, also, m1 was the best for a long time, do you still think that holds true after the merger with exon and the moving of production to mexico?
Old 03-26-2012, 07:38 PM
C Jones
Hunter: Yes..that's a Porsche 996 twin turbo...and yes, they come from the factory with Mobil 1 0W-30 in them and Porsche has a very short list of oils they "approve"...or you could end up with issues on your warranty. Some of the older models needed more zinc in the forumula to reduce rocker arm wear. A lot of the oils are changing and their formulas are not the same as they were initially. Some of the guys periodically sent off their oil samples to Blackstone Labs in Ft. Wayne Indiana and would keep us all advised on the current makeup of the oils. Somewhere there's a report on the different components in the various oils if I can find it.
Shadango: Good eye...my bad...I'm thinking Porsche and writing in a Dodge forum. My mind was into the tranny and turbos on a Porsche....when you change out the oil on a turbo, there's oil left in the catch can and in the turbos...about a quart. It's too much hassle to drain them so most guys just leave it in there to be diluted with the new oil.
When you change out the oil on an auto tranny, there's old oil left in the torque converter but it's a hassle to mess with...but NOT engine oil...transmission oil. As I said, my bad; your good.
Chuck
Old 03-27-2012, 12:13 AM
henry28 henry28 is offline
Vehicle: 2012 Ram
Color: BLACK
henry28 is on a distinguished road
alright, so i've run mine on conventional since I bought it 3 months ago and have about 350 miles on it. Should I wait for the first oil change or just switch over now.
Old 03-27-2012, 02:37 AM
C Jones
What's the rush...it's already in there. It's not like the dealerships are going to put something in there that will screw up your engine...let it stay till 2K or so then dump it and switch to the synthetic of your choice. Do you know what the dealership uses for their oil changes? I'd run a 5W-20 unless you're in a really cold climate...like maybe Ontario? Porsche runs a Mobil 1 0W-30 because when they produce and ship out the cars they can cover all the regions whether cold climates or not....sort of a catch-all generic approach to oil viscosity regardless of geography. The 0 viscosity is too"watery" for the hotter climates like we have here in california....so there's really no need for the 0 and the 5 weight multi-grade works fine.
I used to run the 20W-50 in one of the turbos because of the heat they generate. These Rams have no need for viscosity like that. The last thing I want to see is a big discussion on which oil is the best. Those discussions usually end up with recommendations made by people who happen to be runnign a particular oil of their choosing. Is it better or worse than another? A good grade of synthetic should work just fine. I happen to be partial to Mobil 1, but the next guy will push Amsoil, or Dino or GTX, or whatever. I used Amsoil in my previous Dodge 3500 diesel dually....but Amsoil is expensive...probably more so than the competition.
Old 03-28-2012, 02:22 AM
MoparDude's Avatar
MoparDude MoparDude is offline
Vehicle: 2012 1500 Hemi Crew
Color: Deep Cherry Red Crystal Pearlcoat
MoparDude is on a distinguished road
The new engines don't require the same break in as our older engines, but, it has to be important to allow the rings to seat in properly, regardless of the better sealing technology they have today. I have heard of engines run on synthetic still showing the cross-hatch on the cylinder walls. I will wait for the first change to switch to Mobil-1 and a Wix filter. You have to think, even with the improvements in anti-wear components the oil gets dirty... something is wearing in!
'12 RAM, '08 R/T Avenger, '66 500 ci. Belvedere
You save the environment, I'll save my dignity.
Old 03-28-2012, 05:00 AM
redshift5 redshift5 is offline
Vehicle: 1996
Trim Level: 4x4
Color: Flat Black
redshift5 is on a distinguished road
i'm old school here. change my oil every 1500 to 2000 miles. use regular oil as per spec now 5w20. remmember when had this nissan and ran a synthetic oil in it crusin to wisconsin. going faster than normal for long period of time. trip was about 4 to 5 hrs. found that oil looked like it was burnt. when i got back put dura lube and got great gas mileage after doing this. will be putting in dura lube into my 2011 after it reachies 25000 miles. been useing it in my 1996 5.9L and still going strong and have 123000 on it.
