Old 03-31-2012, 12:58 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
Originally Posted by Evil Ram View Post
Cheap price = Cheap product don't forget
Cheap price = Cheap product?
Whats "cheap"? Cheap headers are usually $300-$400. Good headers are usually $600+.... ARH's are just overpriced as they have the market cornered. More power to them if they can sell them at that price as they are a good quality product, but that doesnt mean other companies dont have quality products at a lower price point.
Im sure ARH will drop their prices substantially when cheaper LTs arrive for us. Hell, the shorties are probably putting a dent in their sales now as it is.
2015 Camaro 2SS/RS/1LE
Old 03-31-2012, 02:45 PM
Moose612 Moose612 is offline
Vehicle: 2006 Ram 2500
Rep:26
Moose612 is on a distinguished road
I bought shorties cause the ARH were way to expensive
Living the dream.
Old 03-31-2012, 08:22 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Jeep LT's will only match at the heads, it will be a real tossup whether they clear everything else.
You'll also likely need someone who can cut and re-weld your cats into position, and relocate your o2 sensors bungs.
I refuse to use a non coated header, so ARH's are close to $2k
after international shipping and sending them out for ceramic coating.
For about Half of that you'de be better off with coated JBA shorties ($555)
and a 2800-3000 stall Torque Converter ($525)
My Edge TC was last Fall,
Just finished my JBA install today.
It's a VERY tight fit!
Old 07-17-2012, 10:59 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
A guy on DT just put SRT8 Kooks headers on a 2wd truck with only a slight tap on a primary to make it fit! OBX ones should work fine...might need a little TLC on one primary tube, but easy install!
Old 07-19-2012, 09:42 AM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
good info! can't beat the price.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 07-19-2012, 09:00 PM
RAM-RT's Avatar
RAM-RT RAM-RT is offline
Vehicle: 2011 Dodge Ram R/T
Trim Level: R/T
Color: Metallic Grey
Rep:29
RAM-RT is on a distinguished road
Do you guys think the 1 7/8" primary tubes are to big for a lightly modded 5.7?? Will low end torque suffer with the large primary tubes?
Old 08-31-2012, 01:46 AM
DR2V DR2V is offline
Vehicle: 2008 dodge ram 1500
Color: patriot blue
DR2V is on a distinguished road
just finished install of obx longtubes on 08 ram. Sound wicked awesome. Quality is great, not just for the price either. Get lots of double takes at WOT! Best headers I have purchased by far!!! Highly recommend them as an ARH alternative.
Old 09-07-2012, 09:04 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Here is a copy and paste to the post Timmy is talking about. This guy installed Kooks SRT8 longtubes and he also said that OBX longtubes will fit. His truck is a 2011 2wd express. He is running a '10 PCM swap with the rear O2s turned off to avoid the typical codes associated with a longtube install.
"Installed a set of Kooks On my 2011 Ram last Night...
They are Off a SRT8 Jeep.
Got them Pretty cheap used.
I didnt have to do any modification on the passenger side for fitment except remove a heat shield that coverts the rear of the motor mount.
On the drivers side i had to remove the same shield and dent one of the primary tubes about an 1/8th inch to clear the motor mount.
Well worth it IMO
The small dent will not affect performance at all.
*Note*
You will need a longer O2 sensor on the drivers side.
On passenger side you will need to cut the zip tie holding the sensor up so it can reach the header
Old 09-07-2012, 09:33 AM
916Timmy's Avatar
Rep:1443
I also have the question in to figure out how he lengthened the O2 sensor wire. I'll post up when I hear back.
Old 09-07-2012, 09:40 AM
CHVYKLR's Avatar
Rep:252
it would take about 10 mins to cut and solder in an extension if you buy the same gauge wire
