Old 03-25-2012, 08:39 PM
pogster pogster is offline
Vehicle: 2012
Rep:13
pogster is on a distinguished road
Default Installing power tailgate lock...anyone done this?
I want to install a power tailgate lock on my new Ram so my key fob will unlock it along with the doors. Anyone install a Pop & Lock power lock kit and if so did it work properly? I want it to work with the fob and not just the switches on the door. I'm assuming this will work as I want it to.
I downloaded the installation instructions but I'm wondering if anyone had any installation issues, in particular finding the correct wires to tap into. In other words are the instructions reliable?
Any other suggestions?
Old 03-25-2012, 08:46 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
Did you get the mopar kit? If you did are the directns updated for the 2012. I installed mine from mopar and the directns were wrong. The 2011 not sure what's in the 12 TIPM is not the same as 9-10 so the wireing to the TIPM connector is wrong. I cannot remember which wires to use. But it's on the forum. Do a search you will find it.
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 03-25-2012, 09:23 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Keep us updated on how you make out with his mod....If you get a chance post some pics once finished.......
Old 03-25-2012, 09:26 PM
SilverGhost SilverGhost is offline
Vehicle: 2011 Dodge Ram 1500 Laramie
SilverGhost is on a distinguished road
I have the Mopar kit installed, but I decided to cheat. I had the dealer install it when they had to take the tailgate apart anyway because my lock cylinder was stuck. Figured why not just let them do it while they were in there and had the truck.
Old 03-25-2012, 10:11 PM
Vehicle: 2012
Rep:13
I haven't ordered it yet. I wasn't aware there was a Mopar kit so I'll look into it. Prices are likely higher in Canada but what did you pay for the kit and installation?
Old 03-25-2012, 10:18 PM
gysnst2's Avatar
Rep:13
Install was easy. Only problem I ran into was the wiring. But I already, had an idea the wiring would be wrong.
Old 03-25-2012, 10:56 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
give an update on how it works if you diy.
Old 03-27-2012, 10:47 PM
Miami Son Miami Son is offline
Vehicle: 2012 Ram 1500 Sport Crew Cab
Color: Mineral Gray
Rep:26
Miami Son is on a distinguished road
I just installed mine this past weekend. The instructions are OK except when you get to putting all the mechanicals back together and there's no pics or instructions beyond "reassemble tailgate lock assembly to vehicle" or some such nonsense. It is a bit of a juggling act, but easy to figure out. The wiring is another story. Common auto electric protocol says that wire colors are described with one or two colors, the second being the color of the stripe if present. In the case of these instructions both wires you need to tap into are described as TN/LB, which should be Tan with a Light Brown stripe. This did not match what I had on my 2012. Also the orientation of the pics in the instructions of the connectors was not correct, either. Fortunately, the numbers identifying what wire was at what position in the connectors was correct, so I simply went by that and ignored the actual wire colors. Another thing that gave me fits is that the harness for the lock actuator has two wires, a red and a black. There is nothing in the instructions to tell you which goes where. I held my breath and took my chances and it worked. Would have been nice to know that it didn't matter because polarity often does with solenoids. In any case, the install was easy and it is great to have the tailgate lock/unlock with the rest of the doors, especially since I have a tonneau on it.
Old 03-27-2012, 11:35 PM
jacobson.s's Avatar
jacobson.s jacobson.s is offline
Vehicle: 2012 Dodge Ram 1500
Color: Deep Cherry Red w/Silver Trim
Rep:61
jacobson.s will become famous soon enough
Here is a Thread by "brad12kx", he is VERY good at explaining and taking pictures:
http://www.ramforumz.com/showthread.php?t=54067
Mods: Chrome bug deflector, chrome tailgate handle, chrome splash guards, chrome mopar fuel door,WeatherTech floor mats, bug screen behind grille, cabin air filter, painted calipers red...
Wish List: 2013 Ram Headlights, LED Taillights, Tonneau Cover, HIDs, CAI, Exhaust System, Power Locking Tailgate, Catch Can...
Stupid Expensive MODS
Old 03-28-2012, 10:36 AM
Color: Mineral Gray
Rep:26
Very nice write up. My only gripe is that at one point he refers to this kit as being aftermarket only. This is a genuine Mopar product available only from a dealer and not aftermarket.
