Old 03-26-2012, 09:58 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Default Ethanol free 91 octane gas, should I use it?
There are only two stations in my area(not even that close really...) that sell ethanol free fuel. One is way out of my way(right near the drag strip). That's not an option for sure. The other is fairly on my way home from work(maybe 5-10 minutes out of the way at most). I found they sell 91 octane ethanol free fuel. What would you all do?
1) Buy 91 ethanol free fuel and run the 91 SC tune. Get this fuel when I can, and when I can't then run regular 93 octane(most stations don't have 91 here, they have 93).
2) Keep running the 93 SC tune and don't use the 91 ethanol free fuel.
3) Keep running the 93 SC tune and try the 91 ethanol free fuel and see if I might get away with it(doubtful).
93 right now is about $4.30/gal. The 91 ethanol free is about $4.20/gal.
Sean
Old 03-26-2012, 01:22 PM
HemiLonestar's Avatar
Rep:280
The ethanol free should work just fine, the tune is a 91 tune, so a minimum of 91 octane is required. If I could get ethanol free I would.
"Big Red"
2006 Charger R/T
Old 03-26-2012, 01:27 PM
snrusnak's Avatar
Rep:1385
I'm wondering if the loss in performance (from going from the 93 tune to 91 tune) would be offset by the benefit of the ethanol free fuel. I can't come up with an answer over here...
I may at least give it a try and just see if it "feels" any different.
Sean
Old 03-26-2012, 02:16 PM
Rep:280
Ah, you have a Cortex? Highest tune setting on a 3865 is 91. I would say back it off to the 91 tune just to be on the safe side, can't imagine there is that much of a difference.
"Big Red"
2006 Charger R/T
Old 03-26-2012, 02:23 PM
snrusnak's Avatar
Rep:1385
No I have a flashpaq. It is a 3865 and also has a 93 tune. I guess they changed that at some point....?
It makes a (somewhat) big difference, it's only 3hp, but it's also 10lb ft of torque between the 91 and 93 tunes. It's not THAT big of a deal I guess, but 10lb ft is a big deal with the 4.7L which already is missing out on some low end torque due to the small displacement.
I'm just wondering if running ethanol free fuel will give more power over ethanol blend of 10%. Maybe the lost 3hp/10lb ft is offset by the ethanol free 91 octane?
Sean
Old 03-26-2012, 02:48 PM
Rep:2657
Getting good gas around here is almost impossible
If it is leaded, has no ethanol, or is above 91 octane
You have to show your drivers license, then some kind of special I.D., & then you have to sign some special Government form. It would be easier to drive over to Arizona, 160 miles away.
I think Racing fuel, Aviation fuel, & certain Marine fuels are involved in this new program
Old 03-26-2012, 03:00 PM
snrusnak's Avatar
Rep:1385
^yeah the pump says "marine" on it, but it's a standard car size pump, fit's in the tank, and people use it...
Sean
Old 03-26-2012, 03:12 PM
Rep:280
That's because marine engines don't have the same emissions requirements (otherwise all 2 stroke outboards would be GONE).
"Big Red"
2006 Charger R/T
Old 03-26-2012, 03:14 PM
snrusnak's Avatar
Rep:1385
So am I not supposed to use it then?
Sean
Old 03-26-2012, 03:51 PM
Rep:280
No it'll be fine. Marine engines are particularly susceptible to ethanol fuel problems, which is why (I have never seen it and I have been on the water my entire life) you will never see an 'ethanol blend' fuel pump at a marina or for marine use.
"Big Red"
2006 Charger R/T
