Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 03-27-2012, 09:24 AM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
Default Probably a dumb question ?
My 06' PW that came with with the Bilstien shocks needed to be replaced last year. I replaced them with the Rancho 5000's, but after replacing I feel my truck doesn't stay on the road like I need it to. I feels like it is bouncing around a lot. I think the compression of the Rancho is good, but am I getting too much rebound ? I am really considering going back to the OE Bilstien....also i have been chasing the death wobble issue lately and want to try the schocks maybe before replacing tires....please give your feedback. Thanks
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter,SuperChip
Old 03-27-2012, 10:34 PM
ucanthngwme ucanthngwme is offline
Vehicle: 08
Rep:12
ucanthngwme is on a distinguished road
I see a lot of people say to play with the air pressure in the tires. Have you recently added air since the shocks?
Also, the shocks could be a little more stiff since they are new, causing it to bounce around more on rough roads.
Old 03-28-2012, 08:42 AM
05cr125r's Avatar
Rep:116
Hi thank you for the reply. I recently went to 50 psi on my Bfg 315's on the front and a hair shy of 40 on the rear. Now i am at 45/40. Iv'e had the Ranchos on for 5 mos. now and really no improvement.My whole front end is new due to death wobble and the last two things i'm going to do are the Bilsteins and the Nittos.There are a lot of negative comments on the Bfg's and a couple good ones.
