Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Towing
Towing 2nd Gen Dodge Ram Towing Questions
Old 03-27-2012, 12:56 PM
MrQ's Avatar
MrQ MrQ is offline
Vehicle: '98 Ram 1500 2WD
Trim Level: LT
Color: Emerald Green Pearl
MrQ is on a distinguished road
Default Towing an Explorer
I am going to be helping a guy move in the next month and since he can't drive all his vehicles I may be taxing my ram to pull one.
The specs on the Ram are
1998 5.2L Auto
Single Cab, Long Bed
3.55 gearing, 2wd
Class IV hitch
What can I tow or not tow with this setup?
Thanks,
-Dan
1998 Dodge Ram 1500 5.2L V8, 1998 Ford Explorer Eddie Bauer 4x4
Old 03-28-2012, 05:19 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
1998 5.2L Auto
3.55 gearing, 2wd
Class IV hitch
Thanks,
You can safely tow around 5500 Lbs, your entire drivetrain and powertrain can pull or push around 17,000 Lbs but don't try to do it cause you will serious screw up your transmission.
I tow a 32' Travel trailer it's about 5K lbs with my ram van, it has the same setup as you, 5.2L 4 spd autp and 3.55 chrysler 9.25 2wd. It performs well, just make sure you turn OD off when you tow.
Old 04-06-2012, 01:52 PM
SnoopyIsMyHero's Avatar
SnoopyIsMyHero SnoopyIsMyHero is offline
Vehicle: 2001 Ram 2500
Rep:86
SnoopyIsMyHero will become famous soon enough
I had a 98 1500 with the 318 and towed everything from a 1800lb VW Beetle to a 5400lb 56 Pontiac Safari (including a 93 Grand Cherokee 5.2 which I would think is about the same weight as an Exploder) through the Poconos without issues. As mentioned, turn off the OD and make sure your brakes are up to snuff. If you use a trailer from UHaul, those have surge brakes which help some, but your truck's brakes are still doing most of the work.
2001 2500 5.9 4x4. Stock except for exhaust, step rails but I don't care, I love my beast
Old 04-15-2012, 10:34 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Also a help with towing. Try to center the explorer weght over trailer axle's that willmore evenly ditriute over truck and make ride and conrol easer.
