Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
tonneaucovered.com
Old 03-27-2012, 04:24 PM
mamoulian1 mamoulian1 is offline
Vehicle: 1986 dodge ram se 150 royal
Trim Level: se royal
Color: marroon
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
mamoulian1 is on a distinguished road
Default frame swap
Has anyone done a frame swap from a 1st gen to a newer one. To gain access to newer suspension parts. Any thoughts would be greatly appreciated.
Old 07-29-2012, 02:33 AM
MoparGuy86's Avatar
MoparGuy86 MoparGuy86 is offline
Vehicle: 1985 Dodge D250 5.9 2WD
Color: Faded Gray
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
MoparGuy86 is on a distinguished road
I was wondering about something along these lines the other day. I've been thinking about pulling the body off of my 85 and dropping it onto the frame of like a 96 or so, so I would basically have a 96 ram with an 85 body...
Old 08-23-2012, 12:51 AM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
My only question is do you really want to. Your current vehicle is 25+ years old and Does not have to meet current inspection that newer vehicles do. If you changed to a later vehicle running gear in some states you will have to register it as which is ever later the engine or the body. Meaning that if you have current vehicle running gear you would probably have to meet inspection requirements of the later vehicle. It could be expensive and a lot of work to meet these requirements. Using parts off of a newer vehicle could work.
Old 08-27-2012, 11:08 PM
Trim Level: base
Color: blue/silver
I do have another thought. If the body is old enough to be an antique and you register it as an antique vehicle You probably won't have to inspection requirements.
