4th gen tow mirror puddle light change - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 03-27-2012, 06:14 PM
konarider2005's Avatar
konarider2005 konarider2005 is offline
Vehicle: 2009 dodge ram 1500
Color: inferno red
Rep:22
konarider2005 is on a distinguished road
Default 4th gen tow mirror puddle light change
hello all,
so i bought a tow mirror from a guy for dirt cheap because the puddle light was not working on it, so i did some research and decided to try and see if i could change the puddle light by myself and save the dodge shop rate ($$$$) . so i went in and ordered the part i needed:
drivers puddle light: 68087239AA
passenger puddle light : 68087238AA
since the light is not installed it made it alot easier,
where the "outer ring" of the light has a gap you can get a flat head screw driver or knife in my case in and pry it up and it will pop out,
there is two connectors on the back of the light that you just pull of and insert into the new on and pop the new one back into the housing making sure that all the wires are tucked in properly
as you can see on the back of the old one there is rust and corrosion in the "sealed" housing
part number
the new light cost roughly $50 bucks up here in canada.
hope this hwlps someone save some cash!
2009 Dodge Ram 1500 sport 5.7L HEMI inferno red
2008 CAN AM outlander 800 xt
Old 03-27-2012, 10:04 PM
TurboCup87 TurboCup87 is offline
Vehicle: 2012 1500 Sport Crew 4x4
Color: Blue
Rep:28
TurboCup87 is on a distinguished road
Sucks about the corrosion. How old was the light? Would there be a way to do a better job of sealing it from water?
Old 03-27-2012, 11:18 PM
Color: inferno red
Rep:22
the mirror was off a 2010 ram so only a couple years old, dodge has a issue with corrosion and such on there puddle lights and signals on all there 4th gen trucks, ive been thinking about seeing if i could seal it up more but it looks like the water got in right at the connectioins.
Old 08-30-2012, 01:39 PM
Barney1 Barney1 is offline
Vehicle: 2016 Ram 1500
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:15
Barney1 is on a distinguished road
3M and Dow Corning both make products to seal electrical connections in moist situations, like marine and landscaping situations.
They are like a caulking of mastic.
I can not think of the names of the top of my head but any Marine shop could lead you in the right direction.
Update:
Some links for one of the 3M products
http://multimedia.3m.com/mws/mediawe...--&fn=2229.PDF
http://solutions.3m.com/wps/portal/3...K8BC31gv)&rt=d
http://www.walmart.com/ip/3M-Scotch-...-tape/15580190
Old 08-30-2012, 02:27 PM
rmurphy rmurphy is offline
Vehicle: 2012 Dodge Ram
rmurphy is on a distinguished road
The puddle lamp gave out on my driver's side mirror as well (2012 Ram) brought it into the dealership for warranty work and they replaced both mirror's free of charge.
they must be having problems with them all
Old 08-31-2012, 02:08 PM
Rep:15
They are like a caulking or mastic.
Update:
Here is what I have used in the past to seal connection on trailer lights --> Star brite Liquid Electrical Tape.
http://www.starbrite.com/prodcatalog...0Tape%20(Home)
Old 11-22-2012, 09:50 AM
Grimminck11 Grimminck11 is offline
Vehicle: 2009 ram 1500
Color: Blue
Grimminck11 is on a distinguished road
hey where were you able to get the puddle lights i call the dealership and they said they dont carry them?, the only was to fix it is to buy the whole mirror which for the pair was 750. (i dont think the light is worth it)
Old 11-24-2012, 09:49 PM
Color: inferno red
Rep:22
in the original post it had 2 part numbers:
the dealer tried to pull that on me but i just gave them the proper number and they pulled it up right away
Old 03-07-2016, 10:54 AM
raminator157's Avatar
raminator157 raminator157 is offline
raminator157 is on a distinguished road
Did you replace both sides? I read some place online that the puddle lights don't match the ones put in by the factory? I guess the factory ones have a blueish tint and the ones you order are white?
Originally Posted by konarider2005 View Post
hello all,
part number
Matt
