Old 03-27-2012, 08:28 PM
redrum redrum is offline
Vehicle: 2012 ram qc express 2wd
redrum is on a distinguished road
Default All 4th gen owners read!
OK. To all the guys who have lowered their trucks with the belltech kit and thought the kit shifted the axle to the driver side due to the track bar, well, you are wrong. I have been researching this for over a week because I am trying to decide on a lowering kit. I have a 2012 ram express quad cab 2wd, and let me just say the "axle issue" is a factory problem. Here is pics of my truck with 300 miles on it, I took them tonight. Driver side shot of tire, and passenger side. So i think everyone who is still on factory suspension, including 4wds, need to go out and look at your rear. We need to get the factory to correct this issue, how is this even legit? Its rediculous. On to the pics.....
DRIVE SIDE
PASSENGER
Old 03-27-2012, 09:15 PM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
Did you use a fixed position for the camera, by that I mean a mount, mounted directly in the same place measured from the truck exactly the same on both sides? I dont know if it is possible to get an accurate picture unless it is visually obvious to the eye. Also did you measure the rear body to see if the rear body was out of alignment instead of the rear end? Just curious.
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 03-27-2012, 09:21 PM
skinnysfd's Avatar
skinnysfd skinnysfd is offline
Vehicle: 2012 dodge ram 2500
Trim Level: big horn
Rep:53
skinnysfd will become famous soon enough
i have heard alot about the beds on the 1500 and 2500 beign out of wack a little bit and dealers will fix the problem. i know it was the first thing i checked on mine.
2012 RAM 2500 HEMI AFE CAI flowmaster dual exhaust,airlift 5000 bags w/onboard compressor,shaved tailgate,2.5" lift/level tuftruck front springs,bushwacker pocket flares,gear alloy wheels, goodyear duratracs 315/70/17,bd gt hemiplus tuner much more coming
04.5,2006 5.9l cummins
Old 03-27-2012, 09:24 PM
Rep:69
I always check body alignment, among the things on my check list, on a truck I am considering purchasing. I look for anything out of position or doors that are not perfect etc, because if that one things wrong, who knows what else is.
Old 03-27-2012, 09:31 PM
skinnysfd's Avatar
Rep:53
my thoughts exactly
Old 03-27-2012, 09:32 PM
No I did not use a camera mount. It is so noticable it does not matter what angle I have the camera at. And the bed is lined perfect with the cab.
Old 03-27-2012, 09:34 PM
Your tuck has totally different suspension in the rear. Im not sure the axle issues would appear on the 2500 or 3500s. Its just on the half tons, so of course your not going to notice it.
Old 03-27-2012, 09:38 PM
skinnysfd's Avatar
Rep:53
I understand that but on the diesel forumns guys with the 2500's have been haveing some issues with the bed beign out of whack as well. I was just stateing what i have witnessed and read from others to try and help with the op's issue
Old 03-27-2012, 09:59 PM
InDeepWaterBlue's Avatar
Rep:611
Skinny, If it was an issue with the bed that would be nice, nice white flag btw lol
Jacksonsnorth, I didn't use a pod either. I had the camera resting against bed on the body line and the pictures show the same thing. The camera angle and spots are about as identical as you can get free hand
Passenger Side:
Driver side:
Old 03-27-2012, 10:36 PM
Rep:69
Wow I had not heard of this issue and I dont see it on mine. I guess I lucked out, sorry to hear others having this issue. Good luck with the fix guys. I hope they make good on it somehow.
