Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 03-27-2012, 09:01 PM
Silver Ram Silver Ram is offline
Vehicle: 2011 Dodge Ram 1500 4X4
Silver Ram is on a distinguished road
Default Oil Question
Just changed my oil. Installed a Mobile one filter and mobile one 5w20 synth oil. The parts house said the oil filter had some special piece that keeps the oil from draining for start ups. Not sure how much of this new crap is needed? But here's the problem - everytime I start the engine I smell an oil smell in the cab. Any idea what the heck is the problem. Oh, I have crawled under the truck several times and can't find any oil spills on the under side to include the exhaust. Also, I am getting a proper oil pressure reading according to the gauge. Sorry if this is a stupid question. This is my first Dodge, and just want to make sure I haven't overlooked something. Thanks in advance.
Old 03-28-2012, 07:44 PM
CARROLLX42's Avatar
CARROLLX42 CARROLLX42 is offline
Vehicle: 2004 dodge ram
Trim Level: Hemi Sport
CARROLLX42 is on a distinguished road
The thing in the filter isn't anything special. It's called an anti-drain back valve. But the spell may be caused by any oil that spilled on the valve cover or the side of the block.
SUPPORT YOUR LOCAL 16's
MC means club not gang.
Old 03-29-2012, 03:27 AM
5500 5500 is offline
Vehicle: 2012 Ram 1500
Rep:12
5500 is on a distinguished road
Most oil filters have an anti drainback gasket. If the filter isn't leaking and the bottom is dry then a drop or two of oil may have spilled onto the cylinder head or exhaust manifold. Will probably dissappear in a day.
You may want to take a good look on the cylinder head beneath the filler. If you see any standing oil, you can clean it off easily by spraying ther area with non-chlorinated areosol brake cleaner when the engine is cold (just make sure the engine is cold and don't let it splash on painted surfaces).
Old 03-29-2012, 06:31 AM
Will do. Thanks for the advice fellas.
