Old 03-28-2012, 11:33 AM
Snowman11 Snowman11 is offline
Vehicle: 2010 dodge ram
Trim Level: Bighorn
Color: Grey
Snowman11 is on a distinguished road
Default 35x12.5x20
Will these size tires fit on my truck with just a leveling kit or do I need spacers?
Old 03-28-2012, 05:08 PM
itshertruck's Avatar
itshertruck itshertruck is offline
Vehicle: 2012 Dodge Ram 1500 CC
Color: Tequila Sunrise
Rep:15
itshertruck is on a distinguished road
Send a message via AIM to itshertruck
2" leveling kit or the Bilstein 5100 height adjustable shocks, from what I have read, and you should be in the green. If you are staying on the stock 20" rims, you will need 1/4" spacers, otherwise rubbing tire against upper control arm.
If it's too loud, You're too old!!
Dodge the father and RAM the daughter!!!
Old 03-29-2012, 04:46 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Tires will clear with the right wheel specs. What wheels are you running?
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM
Old 03-29-2012, 07:34 AM
InDeepWaterBlue's Avatar
Rep:611
You'd need a spacer if you're running a 12.5" Wide tire or it will rub on the control arm, and at 35" tall you'll need a level lift as well.
Old 03-29-2012, 05:47 PM
tsfischer tsfischer is offline
Vehicle: 2011 Dodge Ram 1500
Color: Dark Green
tsfischer is on a distinguished road
What is the typical offset for an aftermarket wheel for the 4th Gen trucks? I like the look of them sticking out an inch or two beyond the fender.
Old 03-29-2012, 10:08 PM
ramrig46's Avatar
ramrig46 ramrig46 is offline
Vehicle: 2014 Ram Sport Crew
Color: Granite
ramrig46 is on a distinguished road
Yup will need a spacer or a negative offset rim. Personal experience with a + 18mm offset and 295x60x20tire rubbed the upper control arm. Now gonna go with a smaller tire and keep rims. Now selling the tires. Sometimes things don't work...
Old 03-29-2012, 10:18 PM
gmkillr's Avatar
gmkillr gmkillr is offline
Vehicle: 2012 Dodge Ram 1500 Quad Cab
Trim Level: Express package
Rep:21
gmkillr is on a distinguished road
The stock wheels are +19mm offset
I bought zero offset wheels which are 3/4" further out than stock.
With 35 x 12.50 x 20's on them they fit perfect and theres about a 1/2" gap on backside for clearance.
Old 04-03-2012, 10:39 AM
Color: Dark Green
Excellent info! What lift did you go with to be able to run the 35s? You don't have any rubbing issues?? I was thinking about doing a 2.5" level kit, and from my understanding, that will fit a 35" tire, with no issues.
Old 04-03-2012, 11:00 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
I'm running 35's with bistein 5100's up front on stock rims with a 1/4 spacer....no rubbing
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
