Old 03-28-2012, 03:23 PM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
Default Weak Headlights
Anyone know what aftermarket headlights will be brighter for the 98 1500 ram with single bulbs? the siverstars are not doing the job...
HID conversion?
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
Old 03-28-2012, 05:28 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
HID conversion?
I like the HID conversion kit, I'm going to be buying one for my van. Just watch out about those kits, some of them are just low beam and some are combination they have both the high and low beam but the thing to watch out for is when you have a HID low beam and a Halogen High Beam. Alot of times a person read HID high low and they assume it's hid's for both high and low but not always.
The kits range from 30-100 bucks on ebay which is where I plan to get my kit. The only thing you want to check besides the above is if their is room inside the head unit so the plastic doesn't melt.
Old 04-01-2012, 11:21 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
They sell a good kit to up grade headlights in lmc for under 40$. Also check both of your plugs make sure there not corroded an check ground. There's only one for both lights and its behind drivers side light.
Old 04-05-2012, 03:49 PM
Color: tan
Rep:65
I had thought about conversion. Thanks for the Tips on that. I have restored and cleared up the lenses which helped a tad but still I may have to go HID just to see on these country roads at night...
Old 04-06-2012, 12:46 PM
ramfam's Avatar
Trim Level: Base
Rep:21
I up graded mine to extre vision bulbs there brighter and whiter then standerd. Also didn't need to up grade wires or relay. That's another thing to look into. Relays will go weak over time they can get very hot with use and corrode internaly.
