Old 03-29-2012, 03:40 AM
tech1 tech1 is offline
Vehicle: 2012 Dodge Ram
Trim Level: 2500 SLT
tech1 is on a distinguished road
Default Headlights - are there stock quad projector assemblies available to replace duals?
Hi - I have read the threads about customizing an existing dual or quad headlight halogen assemblies to projector and really don't want to chance messing them up (when i was younger I would have done it-lol).
What I really want to do is change my current dual halogen to quad projectors on my RAM 2500 SLT.
Are complete replacement assemblies available (plug and play)? Recently I have seen what looks like factory quads on a few RAM 3500's and they look like just what I'd want to install. Are there any after market available? Are quad or dual projector assemblies available from a Dodge dealer to replace my halogen duals?
Sure do value the input from all of you - it has been very helpful.
Thanks,
Ron
Old 03-29-2012, 04:40 AM
1500ram12's Avatar
1500ram12 1500ram12 is offline
Vehicle: 2015 Dodge ram 2500
Trim Level: Tradesman
Color: Granite Metalic
Rep:81
I haven't seen any factory projector headlights for the rams. But from what I've seen if you go with projector style headlight you will want to upgrade to HID. The output beam of the projector is too narrow for halogen to work properly.
2015 Ram 2500 Tradesman, 275/70/18 Fierce Attitude M/T, 18x9 ?wheels, Custom 13' OEM projectors, 55w 5k HID's, 7" premium display cluster swap, Alpine INE-Z928HD HU, RF 200s amp, 2 10" MTX subs, Factory bumper with fogs added
Old 03-29-2012, 06:46 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Only plug and play projector type headlights are from recon and spyder go with spyder same as recon only cheaper
Old 03-29-2012, 03:43 PM
Interesting about the projector vs the HID - guess I am getting them confused and thought they were the same. Now I just don't know what to do to get brighter and better coverage than my stock dual halogen headlights.
Ron
Old 03-29-2012, 06:34 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
55W HIDs from ****************! Even without projectors the lighting is Amazing
Old 03-31-2012, 03:49 PM
Looks like I'm going to go with Retro Shop - Jeremy's solution using the 55W 4300 Digital Kit. Although pricy, sure seems to be the solution I have been looking for.
Would you suggest I have the dealer aim my current headlights before replacing the cores with the retros? They will do the re-aiming at no cost to me.
Thanks - Ron
Old 04-01-2012, 12:29 AM
Bikenut's Avatar
Rep:73
In my experience, I had to adjust the lights considerably after putting in the HIDs even though they were well aimed prior to install.
Old 04-01-2012, 12:49 AM
dodgert's Avatar
Trim Level: rt
Rep:1061
Putting hid's in stock headlights gives you way to much scatter hence the flashing of oncoming cars projectors and hid's = win win
Old 04-01-2012, 12:50 AM
dodgert's Avatar
Trim Level: rt
Rep:1061
Thanks - Ron
If your replacing why would you re aim them and are you getting new headlights from jj with or with out projectors if you get the projectors the hole you use to adjust stock headlights wont work anymore
Old 04-01-2012, 05:36 AM
Bikenut's Avatar
Rep:73
I haven't been flashed yet
I dont understand why the stock housing would give more scatter than any other bulb. It's just more light, the reflector is the same so the pattern is the same. Although it does make sense that projectors would be more focused
