Old 03-29-2012, 10:20 PM
Vortec100408 Vortec100408 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Gun Metal Gray
Vortec100408 is on a distinguished road
Default Slap in Steering Wheel
I have a 2004 Ram 1500 with 80000 miles on it and have recently noticed that I have a slap in the steering wheel front to back. It feels like the steering wheel itself is loose like it might be a nut or fastener that is holding it on is loose not for sure. Any help would be greatly appreciated.
Old 03-29-2012, 10:24 PM
I push the skinny pedal
Rep:3277
The steering wheel is held on simly by a splined shaft, so it's possible that it could have loosened off, but highly unlikely. It's a simple thing to check, disconnect the battery for 20min, then remove the airbag, you'll see the splined shaft right behind the steering wheel. If it's loose there the wheel should pull right off. If it's loose, just take a large socket with an extention and place it on the solid part of the wheel and whack it back into place with a hammer. That's the simple fix. If it's not loose on the spline shaft, then it's something in the steering column and I have yet to pull that apart.
Kurtis
Old 03-30-2012, 09:44 AM
Thank you for the info. I will give that a try.
Old 03-30-2012, 07:49 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Im not sure quite what you mean by "slap" but I would check other stuff before I went fooling with the airbag. If the steering wheel sort of saws back and forth after hitting a bump or road variation, that could mean bad tie rod ends. If the whole column physically moves, there are 4 bolts that hold it up to the dash that may need tightening.
Sure it'll suck, but it'll make you a man
Old 03-31-2012, 02:40 AM
huntergreen huntergreen is online now
Trim Level: sport
Color: green
Rep:643
is the adjuster that allows your steering wheel to adjust it up and down fully engaged? i always try the simplest things first and move on from there.
Old 03-31-2012, 02:51 AM
Rep:2625
steering wheel SLOP is usually caused by something worn out from the steering box to the wheels
I would not mess with anything in the cab, until everything else is checked out
Old 03-31-2012, 02:54 AM
Trim Level: sport
Color: green
Rep:643
i agree but the op said slap, either way slop or slap can mean different things to different people. some of what is described here i would consider "play". but what do i know.
Old 04-01-2012, 05:56 PM
Play might be a better description, however I just had tires put on so I don't think it is that. What happens is, if you were to put your hand on the steering wheel and push or pull it, it moves in that direction. I hope this is a better description.
Old 04-01-2012, 06:42 PM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
Just the wheel itself, or the whole column?
Old 04-01-2012, 08:53 PM
Trim Level: sport
Color: green
Rep:643
this is one of those things i just might have a pro fix. whatever is wrong, i would hate to have fail doing hwy speeds or even moderate speed and loose my steering.
