Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 03-14-2012, 09:56 AM
WarBaby's Avatar
WarBaby WarBaby is offline
Vehicle: 2017 Ram 1500 Express RCSB
Rep:43
WarBaby is on a distinguished road
Question Light Wheels & Sticky Tires For Launch...?
I'm trying to arrive at an ideal combination of tires and rims for launching my `11 RCSB 2WD Hemi ST. Curiously, the factory 17 X 7 steel rim weight seems very elusive--I've read numbers from 23 to 33 pounds each. Does anyone know with certainty?
To the point, I have a K&N CAI and 14" straight-through muffler. I plan on 4.10 factory LSD gears, Y-pipe, removal of trailer hitch/spare tire/tailgate plus an Edge 2800 stall TC (it is also my daily driver). My truck is lowered 2" in the rear. I would like to use M&H 275/50R17 drag radials that are 28" tall (stock height is 31.6"). M&H specifies a 9" rim for that tire. I have found several 17 X 9 Ultra wheels that weigh between 24 and 25 pounds that are "supposed" to fit. I am thinking about using General Grabber UHP 275/55R17 up front (and on the rear for the street).
Since a tuner is not yet available (and might never be), I intend to have some 1/4-mile fun with the stock engine but...the truck must hook. I want 60' times under 1.8 seconds. Otherwise, there is scant motivation for me to proceed. I haven't spent much money on these plans...yet. So I have to ask you experienced guys, will these mods achieve my goals? Your input will be greatly appreciated before I make an expensive mistake!
Thanks!
Tom/TN
If it's not broken, fix it till it is!
Old 03-14-2012, 11:42 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
SST 17x9 are around 24-25 lbs. You can run Offroad alloy or Durango alloys which are also around 25lbs but only 17x8 but you can prob use your M&H just fine with them.
Some folks screw in Hoosier 28x10 17 to the 17x8 oem alloys.
I run Toyos 275/55/17 (17x9 XD Addict Alloys) on the front and 305/45/18 Nitto Nt555r Drag Radials (18x9 XD Addict Alloys) in the rear for 10 months of the year.
I use to have a set of screwed in slicks but sold them since i had lost interest of doing track times.
chefred uses Procomp rears and is running 12's not sure what his 60ft is.
Old 03-14-2012, 03:05 PM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
Sounds like a good plan,
The only possible issue I see is without correcting your tire size/speedometer with a tuner,
you may hit the governor (105mph) before the end of the quarter and fall on your face well short of the traps.
at about the 1000' mark you'll be moving around 90 MPH, but your speedo will register 105 mph and the governor will retard your the throttle.
(about 10% smaller tire = speedo reading about 10% too fast)
I have a similar list of mods on my 10' RCSB 4x4 (about 300 pounds heavier than a 2wd rcsb)
and get 13.8's @98 MPH, 60' times are 1.8's (with a tune) but only an open diff with shitty 3.55's, DA here is usually over 2500'
only weight reduction was the spare removed. (tailgate and bakflip tonneau still on)
I run M/T 295/45R17 ET Street DR's on all 4 corners and often use 4WD auto for a full throttle launch since I added the Street Edge 2800 stall TC.
in ideal conditions with good track prep, a fresh layer of traction promoter I can still hook in 2WD.
Total weight for tire and wheel combo(17"x9" Moto Metal alum wheel) = around 60lbs ea.
that's about 30 pounds lighter than my 305/50 Terra Grappler's on stock 20's I use for the street.
(truck is a half second slower on my street tires) effective gear ratio goes from 3.55 to 4.30:1 when I swap to my M/T's
Tires measure about 11" wide x 27" tall mounted. DOT legal so I can swap them at home and drive them to the track.
If I had a rear locker or limited slip and 4.10's I bet I could hit 1.7's for a 60 footer in 2WD. current best 60' is 1.870
Old 03-14-2012, 03:08 PM
Color: Satin Orange
Rep:627
Nice to see you posting again
Old 03-14-2012, 03:18 PM
Rep:561
Get'n rev'd up for race season again after a LONG Winter hibernation.
Track re-opens end of April
and with any luck the evening air will still be cold enough to get our DA down.
Old 03-14-2012, 03:19 PM
HemiSwagg's Avatar
HemiSwagg HemiSwagg is offline
Vehicle: 2012 Ram 1500 Express RC
Color: Mineral Gray Metallic
HemiSwagg is on a distinguished road
You are right! Getting 17's will need a tuner to compensate for the 105 mph guvna. SUCKS...I want the same set up u have BlackRamHemi.
Thinking I will put some DR's on my stock 20x9's and get a set of SRT 22X10's for my daily set up till a tuner comes out.
I am currently doing 2.3 60ft's at 15.01 in the 1/4 at 2600 feet above sea level with just a cherry bomb muffler and K&N drop in ; )
K&N Panel Filter, Magnaflow Ypipe, Cherry Bomb Muffler, In-cabin air filter mod, 3.92 with LSD, Fastman Standard MOD TB.
Old 03-14-2012, 03:21 PM
HemiSwagg's Avatar
Edit: actually 3600 ft. above sea level
Old 03-14-2012, 04:28 PM
WarBaby's Avatar
Rep:43
Smile
I was not aware of the governor/tuner issue. Thanks for the heads-up on that and all other informative replies. A temporary solution for me (until tuner availability) might be to run our local 1/8 mile track instead of our 1/4 mile track...heh heh!
There are a couple of cocky eco-boost pilots around here whose personalities could benefit from some therapeutic humility. Being compassionate toward my fellow man, I am willing to render that therapy to them...a la 5.7 Hemi.
Old 03-14-2012, 05:19 PM
Rep:561
Last Fall there was an ext cab eco douche talking up his ride at the track,
I kept trying to line up with him but he would always jump to a different lane to get away from me
(we usually have have 4 or 5 lanes that merge into 2)
He was running low to mid 15's and wanted nothing to do with me when he saw me pulling high 13's,
even my buddy with a 10' QC 4x4 Hemi (on stock 20's running 14's) couldn't get him to bite.
He swore he'd be back with upgraded turbo's/tuning next time out, I sure hope so, I've got some new toys on order too ,
also got a couple SRT8 Jeeps to teach a lesson too (again) this year Cant Wait to get Back!
Old 03-14-2012, 07:21 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I have to spray to get 1.7 60's, I need a tq verter to get 1.8's (and I'm modded heavily)... i think your first goal is to get sub 2.0 60's , dr's, tq verter definitely helps but since you don't have a tuner it will be difficult altho the 4th gens are pretty quick...
