Racing in 4WD?? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 03-31-2012, 01:25 AM
Blackbird Blackbird is offline
Vehicle: 2014 Ram R/T
Blackbird is on a distinguished road
Question Racing in 4WD??
Hey all! contemplating getting a 4ws Express with 3.92s....
Can you race a 4x4 truck in 4wd (4wd Lock) at the track? Will I break anything? I was considering a 3200 stall converter with 4wd on and I wouldn't have any traction issue at the track.....is this safe?
I am not new to drag racing but I've never owned a "true" 4x4 before. I know diesels always drag race in 4wd when possible.
Old 03-31-2012, 07:50 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
others will chime in but I think they are using 4wd Auto.
Old 03-31-2012, 10:14 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
yes you can..badblack will chime in, he always runs in 4x4..no traction issues like us 2x's have
Old 03-31-2012, 10:31 AM
BLKSVT's Avatar
BLKSVT BLKSVT is offline
Vehicle: 2010 Ram 1500 4X4 Hemi
Color: Brilliant Black Pearl
Rep:222
BLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura aboutBLKSVT has a spectacular aura about
Sure you can bro!
"MPG???...I get Smiles Per Gallon!"
2010 RAM SPORT CC 4x4 Hemi
Diablo Tuner, Mufflex 14, Bilstein 5100 leveling shocks, 3.5 lift, 35 in mud tires
Old 03-31-2012, 11:13 AM
Thanks guys!
Do you have to worry about anything breaking like tie rod ends, ball joints, etc?
Old 03-31-2012, 11:41 AM
BLKSVT's Avatar
Rep:222
Racing a stock vehicle always has that potential, launching may snap something. I don't think the engineers at Mopar thought about these trucks being raced off the lot.
Old 03-31-2012, 08:50 PM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
I can crush the local R/T's with my 4x4
3k stall and 4 shorter Drag Radials, 3.55 gears
In fact I can even run door to door with SRT8 Jeeps.
I only use 4WD when track prep isnt 100% and traction is questionable.
and even then I only use 4WD Auto (AWD mode), that only engages front driveshaft when rear slip is detected.
Old 03-31-2012, 10:25 PM
Thanks a lot MB!
Without the shorter tires and 3.92s, do you think I could hang with a stock R/T in 4Auto?
Old 03-31-2012, 10:47 PM
Rep:561
Reg Cab or 4 door?
Not likely without DR's
My effective gear ratio on DR's is 4.30:1
and I drop 120lbs on lighter 17" wheels and DR's
every 100lbs will drop your ET by a 10th,
and R/T's are featherweights at 300lbs less than my RCSB 4x4
R/T TC is a 2600 stall, stock Ram is only 2300.
A great launch in 4wd really needs a higher stall torque converter...at least 2800-3000
Old 03-31-2012, 10:55 PM
Reg Cab or 4 door?
every 100lbs will drop your ET by a 10th.
Sorry, I forgot to specify... This would be a RC/SB with 3.92 and limited slip diffs.
But here's, the thing This truck will be a commuter as I drive 70 miles a day to and from work. So I want to know if I can hang with an r/t on the street with street tires in 4wd? I read a lot of your posts and see your truck is more of a racer/weekend toy sort of thing and I can't justify slicks for the 2 times a year i go to the track. And I promise, I'm not stalking you!
