Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Dodge Ram Decals
Old 03-31-2012, 11:46 PM
dksram's Avatar
dksram dksram is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Rep:27
dksram is on a distinguished road
Default A/C freon, switch or condenser fan?
I searched the forums and did not find anything helpful.
When I am driving highway speeds my A/C will stop cooling then start again. Last summer I replaced the condenser fan and that was not the issue. It works when at idle but when driving it begins to stop. Seems that the hotter the outside temps are the worse it gets.
I was told that the pressures could not be checked correctly unless they recharged the system? huh?
Please, any info will be gratefully appreciate.
Thanks
Old 04-01-2012, 08:29 PM
lonncarr lonncarr is offline
Vehicle: 2011 Ram 1500
Trim Level: Standard
Color: Gray
lonncarr is on a distinguished road
I don't understand why the pressures cannot be checked without recharging the system...But it does sound like the charge is low. If it is low then there is a leak, but either way you need to get it hooked up to a set of gages to determine the levels are correct and, if so, if there is a pressure issue. Since it only quits cooling at highway speeds it will definitely not be a fan not working since the fans are only pulling air when the vehicle is rolling 25 MPH or less. The only other thing I can think of is a dirty coil. You can go to an A/C store and buy a gallon of coil acid that works great with a pressure bottle and a water hose...be sure not to use high water pressure or you will bend the fins.
Hope this helps.
Get in, Sit Down, Shut Up and Hang On!
Old 04-02-2012, 05:01 PM
dksram's Avatar
Rep:27
Well I found a shop that would check the a/c and they said it's almost perfect and could not find a reason to add freon. He said if anything it was almost high but that was because it had been running for a while before I took it in.
I'm wondering if the condenser fan motor I replaced could be bad or have a small short in it to cause it to cut in and out?
Now I wanted to ask one other question.
There are 3 positions on the control panel for the A/C 2 of which are recirculation.
If the switch is set on one of those can that make the a/c stop cooling for a minute or more?
Old 04-02-2012, 05:08 PM
DonDoner's Avatar
DonDoner DonDoner is offline
Color: Brilliant Black Crystal Pearlcoat
DonDoner is on a distinguished road
sounds like the evaporator is freezing up. might be a bad thermo sensor at the evaporator.
Ram'n it where ever I can!
Old 04-02-2012, 09:19 PM
dksram's Avatar
Rep:27
Any photos or diagrams of where it's located?
If it was freezing up would it not go longer without cold air? The longest I think it has ever stayed blowing warm air was about 2-3 minutes at any given time. You also get that damp odor too.
At this point who knows. I just can't afford to let the stealership or shop play hit and miss.
Old 04-04-2012, 11:16 AM
dksram's Avatar
Rep:27
Well I really did not like the guys explanation of how my a/c was close to being on the high side so a friend of mine knew someone at a shop with some equipment and they checked it for free.
Crossing my fingers that it's fixed.
RESULTS: 1.63 lbs. required. System had 2.74 lbs.
Truck was purchased used. A/C acted up last summer but I missed diagnosis because the condenser fan motor went bad and I just assumed that was the whole issue.
Conclusion: Never assume it's fixed until you do a complete workup.
I should have had everything checked properly last year.
Like a lot of other men. I had a case of MAN SYNDROME=thinking I knew everything..LMAO
Guess Whut?
Thanks everyone.
Old 05-25-2012, 09:23 AM
dksram's Avatar
Rep:27
Well its back. Someone know where that THERMO sensor is located? Is it attached to the EVAP?
Old 05-25-2012, 09:43 AM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2875
I don't know beans about A/C
I am just wondering if you have typed into YOUTUBE
Dodge A/C trouble shooting
, if you have NOT, believe me, you should
especially the 3 Heatertreater videos
http://www.youtube.com/results?searc....0.W6to2b0fq30
Old 05-27-2012, 02:08 AM
dksram's Avatar
Rep:27
Anyone know exactly where the DRAIN HOSE is for the a/c evap core? I see where a few drops have hit the frame but can't find it for nadda...LOL
Old 06-04-2012, 07:53 PM
THK THK is offline
Vehicle: 02 Dodge Ram
THK is on a distinguished road
Before you go spending any money on parts and trying to fix a problem that you don't know about, have your friends shop perform an a/c performance test.
You might find that the orfice is clogged or sticking, or maybe a high or low pressure sensor is going bad or maybe a thermostat in the evap. In todays 134a systems, a couple of ounces either way can effect a/c performance. Running a performance test with the gagues connected might give you a clue onh whats happening.
Anyway, stop throwing money at it in the hopes that you might fix it. There is a reason the previous owner added excessive 134a to the system.
