Wheel offset - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-01-2012, 08:01 AM
20115.7's Avatar
20115.7 20115.7 is offline
Vehicle: 2011Ram
Trim Level: SLT BIG HORN
Color: Brown
20115.7 is on a distinguished road
Default Wheel offset
Just bought some sweet 20x9 Incubus wheels for my 2011 Bighorn. My question is, the offset on the new wheels is 10mm and the stock 20's offset is 19.5mm...will i have rubbing issuse? Tires will be the same as stock 275 60 20. Thanks.....
Old 04-01-2012, 08:51 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
I think you'll be ok. 9mm difference is appox 1/3". now if you ever go with a taller or wider tire you may run into problems.
One way to check would be to turn your steering wheel to full lock left and right. stick your head under there and see how close your stock setup is to the suspension parts at full lock. if you have at least 1/2" of clearance I think you'll be ok with your new wheels.
Old 04-01-2012, 11:04 AM
roadrnnr's Avatar
roadrnnr roadrnnr is offline
Vehicle: 2011 Ram SLT
Color: Rugged Brown
roadrnnr is on a distinguished road
Does anybody know what the stock offset is on the 17x9 wheels?
road................
Old 04-02-2012, 10:29 AM
ramrig46's Avatar
ramrig46 ramrig46 is offline
Vehicle: 2014 Ram Sport Crew
Color: Granite
ramrig46 is on a distinguished road
Should have no issues since U are goin with a stock tire size. +10mm offset will bump the tire out a little past the fenders just a bit tho.
Old 04-02-2012, 10:30 AM
ramrig46's Avatar
Color: Granite
I had problems with a 295 tire with a +18mm offset and were hitting the upper control arm by 1/8 inch
Old 04-02-2012, 02:15 PM
CHVYKLR's Avatar
Rep:252
what was the aspect ratio?
Old 04-02-2012, 02:53 PM
ramrig46's Avatar
Color: Granite
60 aspect ratio.
Old 04-03-2012, 04:07 PM
20115.7's Avatar
Vehicle: 2011Ram
Color: Brown
Default Info
Thanx 4 the info boyz....I'll post sum pics when I get my new rubber.
