Old 05-03-2013, 04:58 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
Mine would occasionally run rough and the light would flash. I had a p0300 "Random misfire". I replaced both upstream 02 sensors and that fixed it.
Old 05-03-2013, 05:00 PM
lindengauthier420 lindengauthier420 is offline
Vehicle: 2005
Color: grey
lindengauthier420 is on a distinguished road
Haha km lol. Thanks man. People say that with the light o n thier gas milage went down. Is that true or it wont effect that?
Old 05-03-2013, 05:01 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^it depends. If it's an upstream O2 sensor then yes it will effect mpg. But your code is a downstream O2 sensor, which has no effect on anything except monitoring emissions.
Sean
Old 05-03-2013, 05:03 PM
Vehicle: 2005
Color: grey
Ok. I am thinking of putting an exhaust or doing a cutout. That wont turn the light off or will ot?
Old 05-03-2013, 05:04 PM
Vehicle: 2005
Color: grey
Oh and much were your o2 sensors?
Old 05-03-2013, 05:21 PM
Vehicle: 2005
Color: grey
Hey do u or anyone have a 2005 hemi. What do u average for mpg?
Old 05-03-2013, 06:25 PM
Vehicle: 2005
Color: grey
So the code i got 0420 is nothing major and wont do no harm? And how did u know which o2 sensor was shot anyway?
Old 05-03-2013, 08:33 PM
snrusnak's Avatar
Rep:1385
Changing the muffler or adding a cutout will not effect the engine light.
An 05 hemi ram should get somewhere around 15mpg avg.
P0420 signifies a downstream(post cat) sensor. It could be either side if there are two(probably is two). It's either the sensor(s), the cat(s), or a wiring/harness issue.
There are other possibilities but unlikely. An exhaust leak, coolant leak(into the engine), etc can cause this. But if you don't have any running issues they are highly unlikely.
Sean
Old 05-03-2013, 08:35 PM
Vehicle: 2005
Color: grey
But if its running fine you think its the o2 sensor?
Old 05-03-2013, 08:37 PM
snrusnak's Avatar
Rep:1385
that'd be my guess. Best place to start is to inspect the harness to look for frayed wires or loose connections. Disconnect and reconnect the downstream sensors and see if that helps. You can also clear the code and see if it comes back.
Sean
