Old 04-01-2012, 04:14 PM
blackoutdodge's Avatar
blackoutdodge blackoutdodge is offline
Vehicle: 2001 dodge ram 1500
Trim Level: sport
blackoutdodge is on a distinguished road
Default puddles hurt my truck
so recently when driving off road like a child when water splashes or a lot runs down under the hood it just chugs its self off.. not sure if its the cap or plugs or intake..? lost
Old 04-01-2012, 04:25 PM
SnoopyIsMyHero's Avatar
SnoopyIsMyHero SnoopyIsMyHero is offline
Vehicle: 2001 Ram 2500
Rep:86
SnoopyIsMyHero will become famous soon enough
My first thought is cap, then wires. Pull the cap and look inside, is it damp? Are there signs of arcing? When was the last time you replaced it and the wires?
2001 2500 5.9 4x4. Stock except for exhaust
Old 04-01-2012, 04:28 PM
Trim Level: sport
i havnt in a while. its been sitting for a month now but should be running in a couple days i destroyed the od casing and 231 transfer case.. so bought a dld and new housing and gonna weld in a new brace lol. i was thinking cap to but i wanted to get another opinion before i started buying parts. thanks!
Old 04-01-2012, 05:02 PM
Rep:86
Nice thing about tune up parts is...you will eventually need them so buying them isn't a waste of $
Old 04-01-2012, 05:26 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I second the cap. I'd do a good check to make sure the wires are sealing on top of it too. Keep a can of WD-40 in the truck and even if after you swap out the cap and rotor, it's nice to have as a wire dryer to get it going again.
Old 04-02-2012, 12:20 AM
Trim Level: sport
yea thats what ive been using haha. thanks. im pretty rough on her but she can usually do what i want her to lol
Old 04-02-2012, 02:24 AM
Rep:2642
spray a light coat of WD-40 in the cap, spark plug wire ends, both ends
but before you do, check the inside of the cap for a metallic trail left from the rotor if you have one,
as a joke we used to use a number 2 lead pencil to mark the inside of the distributor cap, the vehicle will never start with a lead circle inside there
Old 04-05-2012, 12:20 AM
B.N.Bdroppinacummins B.N.Bdroppinacummins is offline
Vehicle: 1983 dodge w350
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
B.N.Bdroppinacummins is on a distinguished road
its not the cap cant be....it would be your tail pipes when water gets in your pipes it shuts off just like when we get water in our pipes we cant breathe same as a truck. ask the guys who go mudding, it happens alot!!!
Old 04-05-2012, 06:01 AM
Rep:86
I beg to disagree. If you are even remotely on the gas, water and the exhaust isn't an issue. We off road with VW Bugs and even with their little motors, if you keep a little throttle, it won't choke from water blocking the exhaust. BUT, get a little water under the cap and they are down for the count which is why we seal them up tight. And the OP mentions water splashing up and flaming out, not drowning it in a sinkhole. I still stick to my opinion it is ignition.
This one flamed out because of ignition and the tailpipe is a good 8" under water
and to just keep it Dodge-related...here's my son in his Dakota coming to pull us out.
Old 04-05-2012, 07:19 AM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:47
gusman is on a distinguished road
You have a CAI? My buddy has an airaid on his 98 ram 5.2 and even going thru puddles in his neighborhood she would chug and quit. Took a cardboard box as a tempoary fix for wheelin, cut a hole for the tube, left the top open, and she never died again even after some serious mud puddles..
