Old 04-02-2012, 10:55 AM
Jdsram Jdsram is offline
Vehicle: 2003
Trim Level: Slt
Color: Atlantic Blue
Jdsram is on a distinguished road
Default Cam for 03 ram hemi??was told it won't work???
I have a 2003 ram with the 5.7 and want to do a performance cam swap and I was told that my year was impossible to tune and cam. Why is this? I would really like a cam so any help would be great.
Old 04-02-2012, 01:44 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Im sure a mild cam would be an option i would call Stu at inertia motorsports and find out what your options are for cams and tunning.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 04-02-2012, 02:21 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
What Ram tex said...
Old 04-02-2012, 02:51 PM
Vehicle: 2003
Trim Level: Slt
Thanks guys! I have heard Stu's name along with inertia motorsports a lot around the forums. So that's what's I'll do give them a call. Thanks again
Old 04-02-2012, 10:53 PM
HemiLonestar's Avatar
Rep:274
Usually for an 03 (quad cab anyway) comp 260 with a spring upgrade is good.
"Big Red"
2006 Charger R/T
Old 04-02-2012, 11:25 PM
I push the skinny pedal
Rep:3277
For programming the '03, the SCT seems to be the tuner of choice for the heavily modified crowd. As others have recommended, check out inertia for a good cam. Other options are the Comp Cams, but it'd help to know whether you're a rc/qc 2wd/4x4 before recommending what cam to look at. Also, you need to be very honest about what your needs are going to be when it comes to choosing a cam.
And one thing you must be well aware of, you need to upgrade your springs and retainers to at least the 6.1L ones as the '03 has been known to have weak stock springs and will eventually drop a valve if you have a higher lift cam.
Kurtis
Old 04-03-2012, 01:35 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
they are harder but not impossible to tune...i've installed 260's in 03's and it wasn't too hard to tune... just dont get a real radical cam..260, sidewinder, a custom grind from stu...
Old 04-04-2012, 07:24 AM
Rep:274
You CANNOT tune an 03 hemi with SCT (you can tune the 4.7 though). Your only choices for the 03 hemi are diablo and superchips. For custom it's diablo only. If you swap in the 05 PCM & harness then you have options.
"Big Red"
2006 Charger R/T
Old 04-04-2012, 10:39 AM
RamTex's Avatar
Color: Stone White
Rep:366
You heard it from the man i new they were a PITA!
Old 04-04-2012, 11:01 AM
chefred112's Avatar
Rep:656
I know it's been awhile but I thought I was able to use a psc1 with a superchips tuner to tune one of the 260 installs i did...
