Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-04-2012, 02:00 AM
bigred0311's Avatar
bigred0311 bigred0311 is offline
Vehicle: 2010 Ram Crew Cab 2wd
Trim Level: Big Horn Edition
Color: Off White
Rep:50
bigred0311 will become famous soon enough
and as far as the fan coming on due to a high temp that i would not know either. the only time i have seen my fan ( not heard ) come on is when the a/c is running. i dropped all my settings across the board 23 degrees on my predator cause i figured that was change from the stock t-stat to my new jet. so the high would have been 199* and the closest my coolant to getting that hot was today when it got to 190* ( but on that note i had to go to dodge today to get my horn replaced cause it stopped working ) so also i reverted back to my original back up and stock tune. so maybe thats why it got so hot.
i got my 180 t-stat early on as one of my first mods like 2 weeks after getting my truck so i never really payed attention to the temps i was running at untill i got the t-stat.
My Build Thread- http://ramforumz.com/showthread.php?p=781468#post781468
Old 04-04-2012, 08:06 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Yeah I used to monitor my temps when stock and while moving it seemed like 203 was were it hung out. Now it's like say 93 when moving. So I dropped the tstat temp by 15 deg (theoretically) but it was actually only a 10 deg tstat drop (since I tested it and it opened at more like 185). So my operating temp dropping 10 deg makes sense to me (same drop as the tstat...)
Sean
Old 04-04-2012, 08:42 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
It sounds a lot different at high speed. You can watch it.....start the truck and turn on the ac before it warms up to operating temp and then let it creep up to your high speed setting. My fan will cool the truck from 195 ish down to 181 pretty dang quick on high speed!
Old 04-04-2012, 08:47 AM
snrusnak's Avatar
Rep:1385
My issue is I don't know what speed I'm adjusting with the SC tuner(it only has one adjustment). I assume it's the low since it doesn't really drop the temp fast, it more like holds the temp.
One of these days I'll play with the wiring in the fan and apply power to the low/high speed wires to listen to it to see how it's running with the SC tuner. I still think I'll eventually get an aftermarket controller. Either way though, I am not having cooling issues, just want more control over the fan speeds/settings.
It sounds like from what you're saying the fan speed with AC on is low speed. If that's the case then low is all I have apparently with the SC tuner(since mine sounds the same as when the AC is on vs when it gets hot enough to kick the fan on).
Sean
Old 04-04-2012, 09:17 AM
bigred0311's Avatar
Color: Off White
Rep:50
solution- get a diablo sport predator. or the trinity. then you can have more control over then fan
i am excited for the new fan, when its in i will post pics. also i did the cabin filter mod yesterday as well. pics soon to come for that as well.
Old 04-04-2012, 09:22 AM
snrusnak's Avatar
Rep:1385
I don't think diablo has fan control for the 4.7L, unfurtonately. I prefer the SC tunes over diablo tunes though, plus I like the transmission capabilities.
I'll probably be stuck doing an aftermarket controller. That may be a good thing though. Maybe I can hook it up to come on when the trans reaches a certain temp as well, I know my trans gets pretty hot when I sit for a long time in traffic. Although when that happens the fan usually comes on anyway since engine temp rises.
Sean
Old 04-04-2012, 10:10 AM
916Timmy's Avatar
Rep:1443
I got a better idea than swapping tuners....swap to a Hemi
Old 04-04-2012, 10:19 AM
snrusnak's Avatar
Rep:1385
haha. That's not a better idea!
The hemi is great but I love the 4.7L. I am very confident I can hit 400hp (300+ rwhp) with my engine if I can get cams and long tubes. As I sit I'm probably about 350hp.
I think I get good mpg too compared to a hemi, but then again who know because people's claimes of mpg can't always be trusted. Some say they get 18avg and some say 12 avg lol.
Sean
Old 04-04-2012, 11:22 AM
916Timmy's Avatar
Rep:1443
The new 4.7 is a lot better motor than the previous ones. Just get a remote turno and call that 400 HP a day!
Old 04-04-2012, 11:32 AM
snrusnak's Avatar
Rep:1385
^I wish. Don't have the thousands to spend on a turbo setup. I could do $1,500 for long tubes and cams though . That'd be the extent of the performance mods for my truck. I have another project I need to get working on that I'd rather build into a power house. I maybe wouldn't even want to go through the trouble of swapping the cams either, but then again if I'm at say 375hp and cams would push me over 400 I'd probably do it just so I could get a license plate that reads "400hp47" or something like that lol.
Sean
