Old 04-04-2012, 12:23 PM
vandit0022 vandit0022 is offline
Vehicle: 2011 Ram 2500 Laramie Longhorn
vandit0022 is on a distinguished road
yes but are you able to select which type of trailer brakes in the menu? Electric or Electric over Hydraulic?
Old 04-04-2012, 04:50 PM
gysnst2's Avatar
gysnst2 gysnst2 is offline
Vehicle: 2011 Dodge Ram Laramie CC 4x4
Color: Deep water blue pearl coat/Light Graystone Pearl
Rep:13
gysnst2 is on a distinguished road
Yeah did they get the 2012 flash to work on a 2011 evic? I would like to know?
AVS bug guard, Mopar rubber mud flaps, Mopar vent visers, Snugtop cap, Remote tailgate lock, 392 LS, VHT tail lights, 9" LCD headrests, Debaged sides, tinted 20% front 35% rear, cabin air filter mod, topguncostumz 2,25 rear lift coils, bilstein 5100 set at 2.8, and bilstein 5100 rear shocks
Old 04-04-2012, 06:22 PM
kbr577 kbr577 is offline
Vehicle: 11 Ram 1500 Outdoorsmen
kbr577 is on a distinguished road
No you can't switch between the two,I'm not sure what would happen when you hook up a trailer.It does show up on the evic,what %.
Old 04-12-2012, 07:40 PM
mmcglynn264's Avatar
mmcglynn264 mmcglynn264 is offline
Vehicle: 2011 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
mmcglynn264 is on a distinguished road
Still no answer as to how to use factory trailer brake controller on a 2011 to work with electric over hydraulic trailer brakes like they to in a 2012? The controllers seem identical. I would think you could have it flashed to work. Anyone have any luck with this yet?
[B]RetraxPro tonneau cover; Mopar Power Tailgate Actuator; CoverKing NEOSUPREME RED w/BLACK SIDES; AMP Reasearch Powerstep; Mopar Molded Splash Guards; Husky WeatherBeater Floor Liners[/B]
Old 07-21-2014, 10:43 PM
tintoaster tintoaster is offline
Vehicle: 2011 Ram 2500 6.7
Engine: 2010-2012 409ci (6.7L) Cummins Turbo Diesel 305hp 610lb/ft (Chassis Cab)
tintoaster is on a distinguished road
any updates on a 2011 Ram with integrated brake controller and a trailer with electric over hydraulic brakes? best fix?
Old 11-06-2014, 02:29 PM
grsuperv grsuperv is offline
Vehicle: 2012 Ram
grsuperv is on a distinguished road
Default Successful install
My 2012 1500 came with trailer tow package, but no control module. After much research on this forum I was able to determine my needs. My truck came with only one wiring plug, so I had to learn how to add the other wires in order to use the in-dash factory controller. My local dealership refused to assist with any of this by saying it is "impossible to do". Although the instructions I found on this site are particular to the 2010 model, everything matched and worked the same on my 2012. I bought the complete kit from an Ebay seller, printed out the detailed instructions on how to perform the installation from this site and printed out the wiring instructions for the missing plug from this site. I took additional care in removing the dash panels and creating the necessary wiring harness. Even with my cautious pace, I had everything completed and operating correctly in 30 minutes. I took it back to the dealership to have the EVIC updated. They begrudgingly did it for a charge of $45. Luckily, everything works correctly, including the EVIC display. I am very happy with the result, which likely would have been "impossible" without the help of the members of Ramforumz. Thank you!
