Belltech End Links - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-05-2012, 01:11 PM
InDeepWaterBlue's Avatar
Rep:611
Can't blame the man for trying to make a sale, for one won't be doing it. I won't be using my truck for autocross so I'll stick with the one I have on there it's good enough for me. But I will say that if I had an Express I'd go for it, it's a little thinker than what we have and definitely a nice upgrade from not having one at all.
Old 04-06-2012, 02:44 PM
Rep:611
Installed the End links, fairly simple so there's no real install pics. Put the rear end up on jack stand to keep it as even as possible side to side, remove the OEM end links using an 18mm socket and wrench for the top. Use a 18mm wrench to loosen the bottom. To keep the ball joint from spinning, I use an adjustable or Vise-Grips. The instructions say use a 16mm, but they're wrong, go figure lol Now the new dog bone styled end link bolts can be installed using a 3/4 socket and wrench. Adjust the sway bar by rotating it up to line up with the holes and slide the bolts through to hold it in place. Tighten them up by had first then use a Torque wrench and tighten them down to 76Ft Lb's. That's it.
Comparison
Passenger Side
Complete
Old 04-06-2012, 10:16 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
very cool. Mine should be here next week. I kind of figured they would have been a bit shorter.
Old 04-09-2012, 02:06 PM
redrum redrum is offline
Vehicle: 2012 ram qc express 2wd
redrum is on a distinguished road
I am guessing this did not help with the axle shift issue at all?
Old 04-09-2012, 02:20 PM
Rep:611
No not really, it's still there but in all honesty I just ignore it. It does improve the ride quality though, the back end used to like to jump out when I hit a bump but now it reacts normally.
Old 04-09-2012, 02:42 PM
Ramfd's Avatar
Rep:150
glad to hear the handling gets better. The only way to fix the axle shift is by doing something with the track bar. that is the sole purpose of it is to locate the axle under the truck side to side. an adjustable bar seems to be the best answer. just need to figure out how to do it or find one what fits our trucks
Old 04-09-2012, 03:08 PM
Rep:611
Just seems weird that it shifts, when you put a load in the truck it shouldn't shift to the side like that, so why would it if you lower it
Old 04-10-2012, 12:29 AM
Ramfd's Avatar
Rep:150
well let me try and help you visualize why, Sorry if I get too carried away. But I know with me it helps to have a picture sometimes to understand things.
As you can see the track bar has two pivot points, one fixed to the frame (point B) and one mounted to the axle (point A). as the stock suspension sits, the track bar should be level to the ground and parallel with the axle. as the suspension moves through the range of travel point A moves upwards but also in an arc, using point B as the center of the arc. The length of the track bar is determined by the distance from point A and point B as the truck sits level and unloaded. So point A is at the longest point in the arc of travel even before there is any movement. as the suspension moves the axle will try and stay level regardless of the angle of the track bar. Thus as point A moves up and theoretically closer to point B the axle is forced to shift to the right. You have to remember that even though the true distance from point A to point B actually never changes (due to the fixed length of the track bar), the Vertical plain going through point A will 1) remain parallel to the axle plain and 2) shift closer to point B.
You mentioned that the stock suspension does not appear to shift when loaded so why does it do it when lowered. Well I bet it does, but just not enough that we would notice.
If you recall, we had to replace our bump stops with shorter ones with the drop kit. that's because the stock bump stops would not allow that much drop with out hitting the axle. So after the drop was done there is only about a 1/2" of shift to the right. I would bet that even with the stock suspension fully loaded the shift is there but, it is less than a 1/2 in. more like 1/4" in most cases. and I bet most people don't even think to look.
So really all we need to fix it is to have a track bar that is about 1/2" longer to push point A further away from point B, thus shifting the axle back to the right by 1/2". Or you could just drill a hole in the axle mount about 1/2" closer to point B, but i would be afraid that that would weaken the mounting point.
ANYWAY, sorry it got so winded. my head hurts now..lol
Old 04-10-2012, 12:47 AM
Rep:611
I appreciate the long explanation man
