Old 04-03-2012, 07:55 PM
nitro1965 nitro1965 is offline
Vehicle: 2013 Ram Express 1500 Quad Cab
Trim Level: exspress
Color: cherry pearl red
Rep:27
nitro1965 is on a distinguished road
Default my hid lo beams turn off when truck is running ?
i just installed a kensun H13 bi-xeon 6000k hid conversion kit . what is happening is the hid hi and the hid low beams work fine when truck ignition is just turned to the on position . as soon as i start the truck the hid low beams stop working but the hid hi beams work fine ? can anyone help me solve this problem? i have a 2006 dodge ram both my hi and low beams are with the same bulb . my hid conversion kit is suppose to give me both hid hi and low with same bulb.
Old 04-03-2012, 08:51 PM
Supramn Supramn is offline
Vehicle: 2010 dodge ram 1500 big horn
Trim Level: Big horn slt
Supramn is on a distinguished road
I have a newer dodge but form what I have read you may need some sort of error code eliminators or a resistor pack check out the retro fit source . Com I'm working with them I have the same issue but only on the low beam side I have a quad head light system also check out the posts on ddm Tunning too
Old 04-03-2012, 09:25 PM
mikeski's Avatar
mikeski mikeski is offline
Vehicle: 2012 Ram Quad Cab 1500
Color: True Blue Pearl
Rep:25
mikeski is on a distinguished road
Send a message via AIM to mikeski
Hi nitro, it's best to keep the issue in one thread. Then the whole issue is documented in one place.
I know I heard this one before. http://www.ramforumz.com/showthread....&highlight=Hid is a similar if not same problem.
Me.....
Mikeski.....
Morimoto Mini H1 Projector's w/ Digital 55watt 6000k HID's, 35W 10k HID Fog Lights, Blue LED's throughout the interior, Bed and Reverse LED's, Oil Catch Can, 4" vent to stock air box and two beady red eyes. Where will the madness end????
Old 04-03-2012, 10:31 PM
Rep:27
i figured i would get a better response if the tread was new and members can read initial tread about problem rather then having it be missed by being in a tread that is broad. no problem i understand !
Old 04-03-2012, 11:18 PM
mikeski's Avatar
Rep:25
Did that link help any Nitro???
Me...
Mikeski.....
Old 04-03-2012, 11:44 PM
Rep:27
in a way it did i do not have an electrical background so i see there could be a few things going on . i wish someone had the same problem i am having so they can let me know what the fix is . because i didnt buy this hid conversion kit from a local installer they beat around the issue and offer no answer to the problem. when i call kensun where these were from the tech person really cant pin point it i think they are more into selling with basic tech help. im hopeing maybe a resistor harness will work ? like i said before when i turn ignition to on they work fine but as soon as i start the truck the lights flicker once and turn off , sometimes the hid low will stay on for like 5 seconds but they turn off. my hid hi beams work fine. i do appreciate the info you had given me i hope i can find what is causing this. thank-you
Old 04-04-2012, 12:15 AM
mikeski's Avatar
Rep:25
My last idea is the reverse of the no highs. I think you need to look at the connection between the truck harness and the new bi-xenon harness. If you look at the troubleshooting at the bottom of this page -> http://www.headlightreviews.com/kens...t-installaion/.
All you need is a 12v light bulb tester to check this.
Disconnect the harness from the harness
Connect one end of the lightbulb tester to a good ground.
Turn on your lows and touch the other end of the bulb tester rot each of the 3 connections on the harness. Note which of the 3 causes the light to go on.
Hit your highs and do the same thing.
Now, you know which connection is low/high/nothing( ground).
Take that info and compare it to the new harness to see if the connections match. Low/Low, high/High and ground/ground.
If not. You can move the wires in the new harness by releasing the pin appropriate pins and then moving them to where they need to be.
After this. If no one else has anything I would remove and return the lights. Then buy from someone that can support you.
Mikeski.....
Old 04-05-2012, 04:03 PM
Rep:27
i just tried a load resistor wireing harness adaptor and that did not help. someone mentioned to me that because i am useing a slim line ballest is causing the problem i need to use a digital cambus ballest for it to work . anybody have any input on this
Old 04-07-2012, 08:39 PM
mikeski's Avatar
Rep:25
Trout fishing was great. Sorry you lights are still messing up. These things are not always plug and play.
Do you know anyone tat can do the steps I provided??????
me...
Mikeski.....
Old 04-09-2012, 12:42 PM
Rep:27
in ct our trout season starts every year on the 3rd sat in april. well after doing just about everything to get my hid lows to work when i start my truck i ended up getting them to work thanks to someone who sent me one resistor by mail. i ended up connecting the resistor to the stock headlight plug low beam positve and to the negative wires.i went to the truck started the truck and now i have both my hid low and high beams when truck is running with no other problems . thank-you
