Backspacing vs Offset - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-03-2012, 11:49 PM
kristopgun kristopgun is offline
Vehicle: 2010 Dodge Ram 1500 Sport
Rep:18
kristopgun is on a distinguished road
Question Backspacing vs Offset
I am looking to buy a set of 20x10 rims and the rim i like comes in either -24 offset with a 4.5 backspace OR -12 offset with a 5.0 backspace. What is the difference here if any? Which one would stick out the furthest?
Old 04-03-2012, 11:57 PM
Rep:3347
Backspacing is the distance from the inner lip to the wheel's mounting face. Offset is the distance of the mounting facce from the wheel's center line. Negative off set is closer to the inside and positive is closer to the outside.
In your case, the 4.5 back space with -24 off set would stick out more as the mounting face is closer to the inner face and you'd have a deeper lip on the outside.
Old 04-04-2012, 12:22 AM
Rep:18
Default thanks!!
I thought so but my brain was gettin fried tryin to work it out!! Appreciate your help.
Old 04-04-2012, 06:34 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
+1 here
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 04-04-2012, 07:34 PM
Rep:18
Default will they fit ok?
...i am getting an RCX 6" suspension lift and my stock rims are 20x9 with a +19mm offset. I was originally going for a 20x10 with a -12 offset and 5.0 B.S but i would like to move to the -24 offset with 4.5 B.S in order to get them to stick out a little further. I will be running 35x12.5x20....anyone heard of any fitting or rubbing issues with this setup?
Old 04-04-2012, 08:44 PM
Rep:3347
You should be ok with that spacing, the only place I'd worry about would be the lower control arm, but that back spacing should clear it.
Old 04-06-2012, 11:53 AM
Rep:18
Default Thanks bud...
...appreciate your input, just gotta do my shopping around now to source the best price on all the bits and pieces!
