Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Dodge Ram Decals
Old 04-04-2012, 12:09 AM
1999ram2500 1999ram2500 is offline
Vehicle: 1999 dodge ram
Trim Level: slt laramie
1999ram2500 is on a distinguished road
Default 2nd gen rust prevention
fellas, i know 2nd gens are notorious for all kinds of rot so first thing i did when i got my ram was look for rust. sure enough, i found it. fortunately it looks like its easy to prevent. i got a farmer friend who swears by using motor oil or drain oil to prevent rust. guess it soaks in and prevents the reaction from happenin. anyhow, worked perfect on my old yukon so i got a pump weed sprayer from ace hardware, changed the oil, filled it up, and went to town sprayin all up in the bedsides, front wheel wells, and rockers. all the insides of the panels can be reached without taking anything off besides the drain plugs in the rockers. im sure this isnt the best way to do it but its free and like i said, it worked great on my yukon. i oiled the wheel wells before winter and the rust didnt spread even one bit through the winter. havent had the ram for a winter yet though.
Old 04-08-2012, 12:45 AM
paige5k's Avatar
paige5k paige5k is offline
Vehicle: 2002 RAM
Color: silver
paige5k is on a distinguished road
rustoleum has a rust reformer i used it on my bedsides typical bed rot..lol right over the wheel well anyways it worked for me
DARE TO BE DIFFERENT
BET YOUR SWEET A$$
Old 04-08-2012, 09:51 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
I'm working on that now. I got lucky with my 01 it was clean and only surfice on pass rocker and under doors at the seam. So I sanded it down now I've sprayed rockers door sils lower body under doors with paintable chip guard.
Old 04-12-2012, 01:31 PM
hunter.shawn's Avatar
hunter.shawn hunter.shawn is offline
Vehicle: 2000 Dodge Ram SLT
Trim Level: SLT Laramie off road
Color: Pearl garnet
hunter.shawn is on a distinguished road
Same thing here Ramfam Right under the rocker panels and on the door seam... what brand chip guard did you use?
women< my dodge
Old 04-19-2012, 10:46 AM
ramfam's Avatar
Trim Level: Base
Rep:21
A cheap can although it will take 2 of 3m paintable rubber chip guard. Bad thing its black. As you can tell the whole flock is white. So will have to paint rockers to match truck.
Old 04-19-2012, 10:51 AM
ramfam's Avatar
Trim Level: Base
Rep:21
Another thing I like to do is in spring clean under truck. Paint frame a arms and driveline with cheap no name flat black. Seals rust and just makes it easer to clean
Old 04-19-2012, 08:18 PM
ramfam's Avatar
Trim Level: Base
Rep:21
This is what I did with mine. Now paint is rough. I ran out before I finished. Its door sills undre both front and back doors and shadow line on body, rockers.
