Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 04-04-2012, 12:30 AM
TigerBlitz's Avatar
TigerBlitz TigerBlitz is offline
Vehicle: 2002 Dodge Ram
Trim Level: 1500
Color: blue
TigerBlitz is on a distinguished road
Default Trailer Light problem
Just bought a boat to pull with my 02 Ram. My truck already has a 7 plug on the bumper and a 4 pin flat plug underneath my truck. The trailer only has a 4 pin flat plug so I bought an adapter to fit my truck. The 4 pin on the trailer plugs into the adapter and I plug that into my truck. The adapter has 4 red indicator lights so you can see the connection is made. Only 1 red light is lit and I have no lights on trailer. I checked all the fuses I can except the clear square fuses (1-15 on the fuse box lid) and the big light blue fuses(73 on the lid) cause I don't know how to check those. When I use a tester on my truck connections, only one pin lights up the circuit tester. Bought the truck used and 7 pin was already on the truck. Did previous owner wire it wrong ? Any suggestions would be greatly appreciated.
Old 04-04-2012, 08:29 PM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
Sounds like a ground problem.
Old 04-09-2012, 09:33 AM
Ramsail Ramsail is offline
Vehicle: 2012 Ram 1500
Ramsail is on a distinguished road
Are you testing from the 7 way connector or on the trailer side of the 4 way adaptor? Start with the 7 way, sometimes the 4 way adaptors go bad. Always try connecting to the ground pin and the ground to somewhere on the frame. Which pin in the 4 way is lighting up (which light function is working)? Is there any obvious corrosion in the 7 way?
Curt front trailer hitch-Access Lorado tonneau cover-Mopar bed rug-Lund Genesis tailgate seal-Steelcraft black nerf bars-Putco SSR Locker bed rails-and Auto Ventshield bug deflector-Husky Liners Molded Mud Flaps-Thule Roof Rack-Thule Goalpost
