Old 04-04-2012, 01:14 PM
Ramrun's Avatar
Ramrun Ramrun is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Trim Level: Quad Cab SLT
Ramrun is on a distinguished road
Default Diff lockers for ram 1500 MY2011
To All Ram Lovers
I am desperately looking for front and rear diff locks for my 2011 Ram 1500 Quad Cab 4x4...
I looked here n there, and came back empty handed
Helppppppp
Old 04-04-2012, 01:30 PM
Vehicle: '09 Ram 1500/'16 Ram Ecodiesel
Rep:2849
Welcome to this ForumZ
If i am not mistaken, the front differential is still a DANA & you can get parts from several suppliers
Your rear is a new style, made by ZF & people are just now messing around with them
Stock ZF rear differentials have the LSD as an option for the 3.55 & 3.92 ratios
Someone will correct me if i am wrong, but the 4.10 ratio that is in the R/T Ram has LSD as standard
Old 04-04-2012, 01:31 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
There are no locker options (other than factory LSD) for new 11'-12' Ram 1500's with the new rear ZF axles.
There are no front locker options for ANY 1500 Dodge Ram with IFS.
The aluminum housing is not rigid enough for the added torque/stress.
Only HD Rams can install a front locker (SFA)
BTW, since at least 2003,
The Front Diff for the 4x4's has always been a Chrysler 8.0" from AAM
...and the rear a 9.25" Chrysler up until and including 2010's
Not sure who is building the 11'-12' Front Diffs for Dodge now,
but I think they changed the same time that the rears changed to ZF
Old 04-04-2012, 02:06 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
BRH is right about the rear, nothing is out. For the front you can't get an lsd or locker for the 8" diff...ike BRH said its the same front diff since 03.
The 2012 guys are reall screwed bc they have the zf rearend and the 8.5" front diff. Same diff used in some of the newer suvs and rear of the LX's.
[CENTER][SIGPIC][/SIGPIC]
Old 04-05-2012, 11:25 AM
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:134
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
I looked and looked for LSDs for my 2500. I got fed up and called West Coast Differentials and they hooked me up. Worth giving them a phone call anyway. 800-448-0950
Old 04-05-2012, 11:29 AM
Vehicle: 2016 dodge bighorn 1500 hemi
Color: MAXIMUM STEEL
Rep:749
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i would just go with rear lsd, no need for lockers unless you are planning a lot of off roading.
Old 04-05-2012, 11:45 AM
candy08's Avatar
Rep:213
Your possibiltirs are almost endless with LSDs and lockers for a 2500. Not sure why you had such a hard time.
These ZF axles have NO options, Im working on my 5th carrier from an 11. Been around the block a few times with these rearends. The only thing you can do is buy Mopar or wait...
Hunter, the factory LSD isnt bad. Then again it isnt good either. Personally its not enough for me. Maybe I meet that small percentage.
Old 04-09-2012, 05:41 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
umm 5th carrier?! WTF do you do to them?!
2011 Big Horn 4x4 -SnowWhite-
Old 04-09-2012, 08:04 AM
Vehicle: 2010 2500
Rep:134
Dodge put in the 10.5" AAM rear axle in the Hemi 2500. The Cummins diesel 2500 has the 11.5" rear axle and lockers are a lot easier to find for them. I had to go with a Mopar LSD in the rear anyway and went with a Truetrac for the front 9.25" axle.
Old 04-09-2012, 10:52 AM
candy08's Avatar
Rep:213
Haha not my 5th carrier. I mod them for forum members so they can gear their trucks
You're gonna need em when you lift your truck, you goin 4.56!?
