Old 04-04-2012, 03:27 PM
DWare DWare is offline
Vehicle: 2001 Ram 3500
Color: blue
DWare is on a distinguished road
Default newby with exhaust tick on pass. side
just bought a 2001 4wd quad cab 3500. The 5.9 v8 has 119k miles. I have noticed a tick, that sounds like an exhaust leak, coming from the pass side front of the motor. This noise seem to be emitting from, or around a smog pump. The neighboring idler pully also seems to jump a bit. Is this a common problem, with an easy fix? Pump,hoses, manifold,or do I need to look a little deeper?
Thanks, newby Duane
Old 04-04-2012, 04:18 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I would start with replacing the exhaust manifold gasket on that side. It's an inexpensive and relatively easy thing to do, and would rule out whether or not that was the issue. If the sound is there all the time, not just when cold, it could mean a hole in the gasket which will be noticeable when you remove it.
brad
Interested in one of my mods?
